Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 11-15-2013, 11:56 AM
  #12151
Jdeadman, it's not the price of the pad that makes it expensive, it's the priceless time that it takes to keep it working correctly, and endless doubt that comes with such a mod..... On the other hand, the spool is a set it and forget it affair, and you only pay attention to your body&bumper when you hit hard... Voila !!!! Simple and the best solution here !!! No more funny stuff while braking either after only two meets, let alone seven years....
I also run 17.5t blinky buddy not VTA(not really a serious class on the WEST COAST)....lol...
bertrandsv87 is offline
Old 11-15-2013, 12:00 PM
  #12152
Trader Rating: 41 (100%+)
If you dremel out the webbing on the corners there is lots of room
jdeadman is offline
Old 11-15-2013, 12:01 PM
  #12153
Meh you say tomato I say tomato
jdeadman is offline
Old 11-15-2013, 12:29 PM
  #12154
Cool
Ronald Volker says spool(not slipper spool), so you should say spool too....lol.... Don't listen to Bert...lol...
Remember Volker runs a rear gear diff(no slip) on top of the spool(no slip), so why run a slipper spool(slip) and ball diff(slip) in your tc4 .... It would be nice if someone would release a tc4 gear diff in the near future though......
Old 11-15-2013, 12:41 PM
  #12155
Emaculant's Avatar
Originally Posted by bertrandsv87
You'll need a 12.5mm rotor in your motor of choice, and have fun....
Before I buy a VTA motor, Does this goes for a VTA 25.5 motor as well or just 17.5?
Emaculant is offline
Old 11-15-2013, 12:42 PM
  #12156
moparSRT's Avatar
Originally Posted by IndyRC_Racer
Thanks for the info. I never thought to sand just one of the slipper pads to adjust the diff gear mesh.
The biggest advantage to building your own slipper diff for a TC3/4 is that you can use the plastic outdrives (to save weight). While it is not the most durable option, it can be used on a more open track where hitting boards isn't as likely.
Dont bother, been there done that, works with drifting tires but not racing. I build my slip spools with lightweight steel outdrives #31062
moparSRT is offline
Old 11-15-2013, 01:01 PM
  #12157
Thanks MoparSRT I was windering what the best ones would be I have the Blue alum currently but they wear pretty quick.
jdeadman is offline
Old 11-15-2013, 01:15 PM
  #12158
Exclamation
Ray K. won with a spool/lcd combo, and that's good enough for me.... How many real races have the slipper spool folks won ???? NONE !
Old 11-15-2013, 03:24 PM
  #12159
Here is the chassis, really not much to show. I trimmed the Chassis to 94 mm width using a Dremel Cut Wheel.
Attached Thumbnails Team Associated TC4-digtop.jpg   Team Associated TC4-digbottom.jpg   Team Associated TC4-digvtabody.jpg
ElliotCanada is offline
Old 11-15-2013, 03:25 PM
  #12160
alloyslash's Avatar
Trader Rating: 19 (100%+)
The only legal rotor for USVTA is the 12.3 sinntered rotor. It does real well tho
alloyslash is offline
Old 11-15-2013, 03:33 PM
  #12161
Help!!! I'm looking for the Ae part # for the TC3/TC4 front spool, is it the same as solid front axle part# 1703. Also I have a borrowed LRP X12 21.5 I am going to try in my TC4 CTA.(Canadian T/A) The instruction manual suggest 3.5/1 for TC. Also max temp 210*. My Ballistic 21.5, Novak says no more than 160*????.
BE KOOL
THEBIGBULL is offline
Old 11-15-2013, 04:04 PM
  #12162
DesertRat's Avatar
BE KOOL
Yes, the solid axle is a spool, 3.5:1 should work okay for a 21.5 if your track holds some speed through the corners and you're not running a max timing, and 160 is probably just right for good performance.
DesertRat is offline
Old 11-15-2013, 04:36 PM
  #12163
Nice layout Elliot ! 94mm is not bad.....That Car is ready for 17.5t/13.5t for sure... Good luck...
Old 11-15-2013, 05:06 PM
  #12164
Emaculant's Avatar
Nice!!
Thanks, I want to buy a Fantom 25.5 but they sooo many options.
Old 11-15-2013, 05:32 PM
  #12165
Ray k's Avatar
Trader Rating: 47 (98%+)
Yes ,spool and Losi lcd's . No hard bumper , but flush cut axles with the wheel nuts . Which helps protect axles from getting caught on boards . The only problem with hard bumpers ,is they tend to be heavy ,which takes away initial steering .
BE KOOL
Yes 1703 is the spool part no#
I would not start a 21.5 at 3.5 FDR, especially a borrowed one ! 4.0 to start and stay away from the max timing slug .
Ray k is offline
