Team Associated TC4
Hi all.
Guys I need your help.
1. Bought this motor mount from asiatis but can't understand which part i need for connect motor?
1. ASC31020 motor mount
2. ASC3930 motor adjustment cam
3. ASC3931 motor adjustment clamp
The stock ones are black. There are also "Factory Team" versions of these in blue anodized aluminum. Hope that helps.
Quick question for u guys. I've shimmed these diff for 3hours. to the left , right, pinion in and out a shim. but the gears still sound like dog sh*t. any tips? I read earlier that they were kinda noisy at first but theres gotta be a way to quiet them a little more. i think its mostly because the ring gear doesn't run super true. thanks in advance
One thing I always do to all my tc4/ntc3 diffs is install one less spacer behind the pinion gear in the diff, so I can see a little back and forth play between the pinion and the ring gear... Associated tc4 instructions will tell you to put two shims there, but I prefer one or even a thinner shim if the diff box is tight....
I bought a new roller from somebody blew it apart and rebuilt it. i'll try removing a one of the pinion shims again. all my cars have been belt drive but it seems simple enough. i'm thinking that the composite outdrives aren't very true.
Where does the FT TC4 spine plate go?
do they make a tc4 with a saddle packs chassis? i have a guy trying to sell me one but i cant find a brand that makes one. he cant tell me the brand. thanks
Can someone tell me how to get more lateral traction out of my TC4? I have the shocks laying down, i have Assoc. silver springs all around and no shims under the arm mounts. Also, I have diffs front and rear with the front tighter than the rear. Any help would be awesome.
What kind of handling problem are you trying to solve? On/off power steering, entry / mid / exit corner steering or traction?
Gets very lose going in and when I transition quickly from left to right or right to left. I was going to try a front sway bar but I wanted to get some advice from you guys on here first.
