Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 05-04-2005, 01:03 PM
  #4396
RCknight's Avatar
Default PaulTC4...
so far it don't fit and it's mounted very high on the chassis. It could easily come down 3-5mm with while still using a 100tooth spur and it could set level on the wing braces if you went with a 72 spur. I also don't no where I'm going to mount the antenia now. Either I drill a hole in the upper brace or find somewhere else mount it. Do you want to buy it PaulTC4?
I still may try it.
RCknight is offline
Old 05-04-2005, 01:32 PM
  #4397
Originally posted by koabich
Considering the fact that the battery manufactures do not make the batteries for our industry, this may be a little difficult.
Batteries are made for other, much, much, much larger markets, RC'ers just happen to use the batteries as well.
The batteries themselves are only .020 larger in dia - and the same length (GP 3700 vs 3300) - by itself, it isn't much of a problem, but when you add cell shrink and shoe goo, it makes the problem worse. Bare 3700's fit my TC4 just fine with the strap flipped over.
Corner Weight is offline
Old 05-04-2005, 01:35 PM
  #4398
Tracksidehobbys's Avatar
Default need help
does anyone know if there is an aftermarket steering rack for the TC4?
Tracksidehobbys is offline
Old 05-04-2005, 02:49 PM
  #4399
Trader Rating: 26 (100%+)
Just saw one on Ebay under TC4. 3Racing sells them.
http://cgi.ebay.com/ws/eBayISAPI.dll...973222448&rd=1
svines1972 is offline
Old 05-04-2005, 03:11 PM
  #4400
Paul_TC4's Avatar
Default Re: PaulTC4...
I still may try it.
Wait, you said it doesn't fit? Does BMI know that? Sounds like a pain, and it's not even on yet!
Good Luck.
Paul_TC4 is offline
Old 05-04-2005, 03:12 PM
  #4401
Paul_TC4's Avatar
Any word on if that aftermarket rack reduces any of the horrific side play that the TC4 rack has?
Paul_TC4 is offline
Old 05-04-2005, 03:49 PM
  #4402
Wicked's Avatar
Yea from what I have read the 3racing steering kit will get rid of that play.
And its blue too.
Wicked is offline
Old 05-04-2005, 04:17 PM
  #4403
tc4kid191's Avatar
Originally posted by Wicked
And its blue too.
Thats got my vote!!
tc4kid191 is offline
Old 05-04-2005, 05:19 PM
  #4404
RDR
RDR's Avatar
Have a 3Racing steering rack on my car, can't tell you if helped never drove the car with stock one!
Doug
RDR is offline
Old 05-04-2005, 05:42 PM
  #4405
i have the 3 racing rack its lighter the stock and yes it removes all the slop the best hopup part i have bought truely brilliant
gaz8 is offline
Old 05-04-2005, 05:51 PM
  #4406
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Lighter than the Stock Carbon Rack????
How much?? does the Alloy rack weight...?? I have too see this
-Dave
JDM_DOHC_SiR is offline
Old 05-04-2005, 06:10 PM
  #4407
losi jon's Avatar
paul-concerning the antenna and the receiver wire,you could put some shring tubing around the wire to further insulate it,i have used this technique for a long time
losi jon is offline
Old 05-04-2005, 06:14 PM
  #4408
Paul_TC4's Avatar
That's what I was thinking.. thanks Jon!
I'll give it a try.
Paul_TC4 is offline
Old 05-04-2005, 07:27 PM
  #4409
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Paul, you could also poke a little hole in the antenna tub right above where it mounts in the chassis. Then fee the wire through that hole and out the other end. This way there is no part of the antenna wire touching the chassis.
Kraig
KT Hobbies
Kraig is offline
Old 05-04-2005, 10:49 PM
  #4410
losi jon's Avatar
the only problem with doing that is that it greatly weakens the tube...
Paul-no problem.
losi jon is offline
