Serpent S411
#4398
#4401
this is what David Ehrbar let me change at my car.
It gives the car a bit less initial steering and makes it more easy to drive.
you can dremel down the steering posts by 0.5mm or flip them and put 4.5mm shims under them to try the mod.
I like to thank the serpent team at the ETS, they where always willing to help everybody out, A or Q main.
you also need to dremel down the nut that holds the carbon servo piece
#4402
#4404
Do you also add 0,5mm shim between the steering turnbuckle and steering block to keep bumpsteer?
#4405
General setup question.
Hey guys,
Just want to know what change will occur (in general)if I change the front spool to a ball diff.
I would normally just throw it in and find out,but I want to get to my track tommorow all set-up.
Setup= Gear diff rear,TE,10.5 up to 17.5.
Mainly interested on what you all think of corner entry/exit.
#4408
Hey guys,
HiH
Ed
#4409
Hi Everybody,
My ETS-Setup is online on serpent.com including a list of optional parts I used.
Besides the steering-mod (#401512), it could be interesting that I used only one O-ring in the dampers and added 2 more of the #160109 shims instead, so the dampers have much less friction.
Actually it is cutting down 2.7mm. Or, easier: use the steering posts from the S411-FF, like I did ;-)
No, no shims. The point is to change the bumpsteer characteristics.
Regards
David
Regards
David
#4410
David,
I have checked your setup and the reference 401512 doesn't appears at serpent's web. If I check the s411ff the steering shafts are 401400 same as s411te, In the s411ff manual, yes it appears the 401512 reference.
So for the mod, you change the shafts, put it backwards and with a longer screw and add 4 mm of spacer between chassis and bearings, it's ok??
Regards
Regards
