Ask Keven Hebert, TeamAssociated / Reedy / ApexRC
#466
What is a good gearing for a parking lot track ,sugar water? I'm running a tc6 with a Dualsky Z5 17.5.
#467
I think 4.0 would be a good place to start assuming you are running blinky mode. If running with timing unfortunately I am not familiar with Dualsky motor so I could not give you a proper answer but for blinky I think 4.0 as long as you check the temp should get you in the ball park with about 30 degree timing on motor.
#468
Hey Keven, you still using Hotbodies DCJ's on your TC6.1?
#470
#473
#474
Popsicles were great ! bit big but great....
you dont need to do much for the spec-r shaft to fit. All I had to do was to use the 5x10x3 for the inner bearing, use HB Hex and then for the blade, I put a 2mm hex in our curent blade in the hole to make it a tiny bit bigger and then it fits goo on the specr shaft and thats all I had to do !
#475
i got a new tc 6.1 kit i just play. how low trun motor to run and be in the 50 mph
#476
#477
#479
