Ask Keven Hebert, TeamAssociated / Reedy / ApexRC
#316
#317
Kevin,
Glad to see you running the Radiopost radio. They are awesome and I have had mine now since they first came out.
Question. What changes will you make on the radio when you run 17.5 blinky? Also will you adjust the radio much throughout the day to help when track conditions change a bit or will you just make setup changes?
Thanks and when you coming back to WCRC?
#318
Hey RedBullFiXX,
I think what Kevin means is where the caster block mount's to the aluminum arm mount you can put a shim in between there. Also you can add shim's between the lower arms and aluminum arm mount.If you do so your going to have to take off the Graphite brace.
Hope this helps
Hope this helps
Kevin,
I usualy dont change anything other then expo when running 17.5 ! I use about +20% expo on the throttle and thats about the only change I make from mod to 17.5. Hope your car made it ok after the crash in the main at westcoast last time I was there. I think I will be back sometime early december.
#319
#322
It was ugly. $125 worth of damage. It hit the rear perfect. Even ripped the bulkhead screws out of the chassis.
She looks sweet now with all the new parts
Thanks for the continued support.
Hi Mike, yes that is what I was refering to ! thank you
haha thats a tough one ! I have not planned that far ahead but I have a feeling chicky answered below !
Hi,
Hi,
#324
I would probably start with the same setup but maybe had a little bit more droop ! Unfortunately I have never run with no additive so it is hard to say. If you try it let me know what it feels like and then we can work from there.
#325
Hey couple questions Keven
1. What do you mean in your notes in his IIC 12th mod setup it says 2mm on top arm?
2. You used stock/spec with 0-1-1-2 on high bite carpet at IIC with 4T lrp motor correct?
What would you use say on Norcal Hobbies outdoor asphalt to start off with?
Can you advice any other settings for other track conditions?
Also why did you choose the stock/spec over the comp or TC v2 controllers?
Thank you for your time
#326
Hi,
1-The 2mm on top arm means the upper arm is shimmed 2mm to get a longer upper arm.
2- the reason why I run the stock spec is more of a feel thing, I like the feeling of it on the down side is you dont have much setup window since we pretty much can only run it on one. I ran stock spec with 4.0 STD wind with 12.5 works rotor correct.
3- if I was to go run at Norcal, I would start with the same setup with lighter oil on side and center, probably 20 side and 25 center and would use a blue center spring and green side ! thats about it I think.
#329
unfortunately I have not tried the progressive spring in such a long time. last time was over 2 years ago and back then, my 1/12 program was not the best so it would be hard to say. Blackstock did run them on his 13.5 car at IIC and ran black spring on his mod car. Sorry I could not be much help
