Ask Keven Hebert, TeamAssociated / Reedy / ApexRC
#182
how did you make the spec-r work maybe you can help me out. maybe some pic if you have some
#183
Droop setting
Hi Kevin, I am currently copying your setup from the Indoor Champs and I had a question regarding droop:
I am using the HUDY Droop gauge with the supplied HUDY support blocks and according to the set-up it calls for 7 and 6 droop setting. After setting this up with my droop gauge there is little-to-no up travel. I just want to make sure that is how it IS supposed to be. Thanks in advance!
#186
Happy birthday Keven
For set up, where do you place weight on your car? Do you ever run weight in the front or rear to change your set up, or mainly put weight down the middle of the car to make minimum weight? Thanks
#188
Sorry for the delay I have been out of town for the last 3 weeks. I usualy go by feel and then use the AE gauge to make sure it is even. 7 and 6 should give you about 2mm uptravel depending on tire size. 2mm uptravel is where I start at more tracks and then adjust from there droop is very sensitive on a car and is usualy one of the first thing I will play with when I get to a track.
Hope this helps
I would start with the 09 IIC Vegas setup and give that a try. The other thing you could do is try a softer spting all the way around this is how we were running the tc5 in the end. Also, you could try adding more rear toe and camber if it is still not good enough.
was good seeing you at Cactus. Would like to get back there I had a great time but I am not sure if that will happen anytime soon but it is not out of my mind for sure .
Thank you Brad, hope to see you again soon
#189
Hey keven I was wondering if you have a asphalt setup? And do you know if the Tc6 come whit hart plastic parts of the normal.
#191
Hi Keven,
I see on rcprogear.com that you used the X-12 13.5 in 1/12th scale. Could you please post your set-up? Roll-out, rotor, speedo software version, and settings?
It is great to see that The Team is figuring out competitive settings with this combo in 1/12th!
Thanks in advance,
Mike Slaughter
Thanks in advance,
Mike Slaughter
#193
Really?! I had the hard parts in it. Deep black and real hard to put the droop screw in the wishbone.
Standard are the hard parts. Call AE they maybe give you a set hard parts for free
#194
I call AE and the say that the first car came with normal plastic and then after that the came with hart. I don't know why would the do that but if you run in asphalt is better to have the normal. And if you run in carpet then the hart is better
