EPIC "D3" Duo 3
#586
Hey guys, I recently purchased a Team EPIC D3 "Monster Horsepower" 13.5t to run in a boosted touring car class. I'm using a Tekin RS as a speedo.
I've got a problem where I have excessive 'drag' brake during corner entry. I quote 'drag' since I have no drag brake specified on the speedo. The only thing I can think of is that the motor itself is causing the drag. I've noticed that there's quite a bit of 'cog' in the motor when you rotate the wheels by hand - strong magnets, I assume.
I'd like the motor to run a bit freer; my first thought was to add some push control, but it (strangely enough) didn't have any effect. I know in 1/12 that push control works exrtremely well, allowing the car to roll through the corners better. However, it doesn't seem to have much effect with the D3.
Anyone have any suggestions? The drive train runs free, so I don't think the issue comes from that.
Thanks!
(I'm also going to post this on the Tekin RS thread, as this thread hasn't seen much activity lately).
Thanks!
#592
high torque rotor
anyone have any experience with the high torque rotor? im running oval 17.5 spec with 1 cell lipo. wondering if this would be a step in the right direction? its not a real big track but i don't know of the exact size. thanks, matt
#593
Hard to find a 12.5 high torque rotor in stock.
Anyone got a seller ?
#595
Both worked well in 17.5 spec truck class.
#597
Boost or gearing?
Assuming you hit the same temp, is it better to run higher gearing to reach that temp or to add boost? Which would produce the most power and which would be the most efficient?
#599
You need to find a balance between what gearing to run and how much boost to apply, and how fast. This is both a 'technical' issue (you can overheat your motor via heat if you're too aggressive), but it also has to match your driving style.
