EPIC "D3" Duo 3
#496
What is the major difference between lrp x12 and epic duo 3 ? Torque, feeling
On the tech info d3 have amazing 4300 rpm per Volt. Lrp have 3600 and speedpassion 3800
#498
And don't believe anyone's spec sheets when it comes to different companies...
#499
I was running on a x12 10.5 with a tekin
45 boost 15 turbo make the x 12 screaming with 8.0 fdr
But i wasnt like how to the power come, too much brutal.
I hope the d3 is smoother than the lrp when the timing is coming.
#501
Well needless to say I've had to go back to the drawing board on this one...
I've ordered a new stator and will take an extreemly conservative approach next time.
1. FDR 6.7+
2. Motor Timing 'ZERO' - to start with...
3. Tune RS to get max timing whilst keeping temps way cool
4. Get new and more accurate Temp gun!
I've been running SP b4 and no issues with temps.
I've been in the hobby 3 years+ now and this was my first cooking, bit disappointed I guess!
1. FDR 6.7+
#502
Hi guys, can anyone help me with the bearing size on the D3. Thanks
#503
Duo 1 vs. Duo 3???
I'd love to hear peoples comparisons of the Duo 1 vs. Duo 3 motors.
Which is best? (I love my Duo 1)
#504
Still using my original Duo 1s from EA for 13.5/17.5. Got to be 2 years old.
Bill
#505
The Duo 1 always seems to be the fastest motor and we have 'lots' of guys at the club Running 17.5 boosted with the D1, D2 and D3 variants. You can tell when someone is running a D1 as they scream but Everyone who has them uses them sparingly and usually only for big events. Maybe its the timing we are giving the motors but the old one's do not seem to fade as easily at 4 minutes like the new ones do. A lot of guys are still running the D2 over the D3 and although the D3 can handle lots of timing, its in a much smaller sweet spot IMO. Just a matter of whether you can be bothered and have the time to find it.
#506
Tuning rotors
Hi all, am trying to figure out what the different tuning rotors do and would appreciate it if someone can enlighten me.
I have looked at the tuning rotor chart that someone posted awhile back. While it did list the suitability with regards to the different classes of vehicles, it doesn't say how the powerband will be altered.
For eg, going from a 12.3mm broad powerband rotor to a 12.3mm high torque rotor,
A. does it allow for a larger pinion to be used for the same vehicle speed and yet runs cooler?
B. How does the motor's response to dynamic timing advance get affected by such a change? Does the timing advance rob the stator of its ability to turn the stronger rotor, meaning the motor doesn't work as well with high timings?
In addition, what really happens when we change the SIZE of the rotor from a 12.3 rotor to a 12.5 rotor? Or even a 13mm rotor?
Thanks in advance
Thanks in advance
#507
radwerx,
Regarding tuning rotors. My limited experience with Trinity / Epic D3 tuning rotors is that you are required to buy a rotor tester. I bought about 5 different tuning rotors from epic/trinity and they weren't consistent at all. Two bought at different times, that were supposed to be the same strength were quite different ( about 10 % ) . And another one was crazy unacceptably low ( 800 gauss when it should have been at the very least 1200 ).
I was told flatly by epic / trinity email support that the rotor magnet strength was not a warrantee item. I basically was told I was SOL even though the rotor had never been used, right from the package and was 2/3rds as strong as it was supposed to be. Sad, because I'll never buy another tuning rotor from Epic / Trinity due to this policy.
Thankfully , I was very lucky and got great trackside support from EA at the Reedy race. He offered me a replacement.
#508
Someone can tell me how to set the endbell timing on the duo 3 ?
The sensor don't have any clearance to move
I hope my motor is not for timing 0 class
#510
its hard to twist and i m scare about broke it
Tell me if something is wrong, i don't know how the sensor can move on this motor...
Sry if i am realy nooby
