EPIC "D3" Duo 3
#466
For any of you guys looking for a killer deal on some motors look into the Monster Lock motor Trinity has released. Its a D3 with tamper proof windings, a "comm" type lock so the timing ring cant be adjusted or tampered with and is non adjustable timing. Its a killer motor for the price especially for a spec type class that tracks may have that only want to use one motor.
eA
eA
#467
Im the same, can't do Saturday practice as I have my kids to think about and my GF, it's the only time I see them at weekends, so race days are few and far between. Just don't practice enough to really get on top of the racing anymore.
#469
I Currently run some boost with my 4.5 motor in TC. I am running the Lrp Sxx stock spec and boost 1 feel 1 . I am not sure how much this advances the timing on the motor , but i like it much better then no boost at all.
I do not think you would want to run higher turns and more boost as this will get much hotter in my opinion.
Hope this helps.
Hope this helps.
#472
comeseethis.com can give you a pretty good starting point for gear ratios in non timing classes
as for timing on the endbell. A lot of guys crank it all the way up, but I just found that made the motor hot and didn't really seem any faster. I like around 2 or 3 notches over the "0" mark
#473
you need to include which motor for people to help. 13.5? 17.5? 21.5? 25.5?
#474
gearing
I am going to run a Duo 3 17.5t in my SC10. Could anyone give me a suggestion on gearing for this truck.
#475
Hope this helps.
Hope this helps.
I run a 4.5 @ profile 1 on the old SPX. This motor is slower than my lrp x12 5.5! Do you have any tips? I haven't changed the mechanical timing and my fdr is around 9.3 on a medium sized track.
#476
Im running a Duo 3 17.5 in my SC10 with esc timing and geared 22/87. I have run with no timing and geared 29/75. Dont forget to keep an eye on motor temps. My current esc setup is posted in the Speed Passion off road thread.
#477
Well i am not sure how much timing boost the spx has, But the stock spec makes the motor much faster on the top end then the regular sxx. I am also geared quite a bit higher then you. I am currently running 8.0 with 4.5 my motor temps are about 160-180 degree's , This is for indoor carpet, For outdoors i might have to run a fan on the motor.
Also my Timing is one notch past 0.
Hope this helps some.
Mike
Mike
#478
duo 3 rollout
Im running the duo3 10.5 1s in my WGT looking for rollout.
using 1s lipo with new LRP stock esc profile 0.8.10.0
#479
I also just built a pan car for a friend using CRC tires / 69tooth spur and a 30 tooth pinion.
I don't know much about the LRP stock spec so I was conservative on the roll out, think it was around 66mm.
With my BD 72mm is the go.
#480
Hey guys need some help. What fdr should I be looking for? I will be running 17.5 blinky. The motor is in a T3 with a tekin RS. Also our straight stretch is about 75 ft and the track is pretty flowwing. Any help would be great. Thanks.
