Tamiya TRF417
#4832
i have same problem with you mate, try this setup, i enjoyed this setup for my v5 car on medium grip asphalt with small bumpy track
#4834
Odd, that setup should not be a handful to drive. Have you adjusted the shock angles for the X towers? It should be hole 3 front and 5 rear on the X. I also think David ran a putty diff in the front, if you are running that then a spool will be more stable.
Other things to try:
- Kit rear anti roll bar
- Anti dive
- 3.5mm rear wheelbase (with 0.5 or 1mm front)
- Anti dive
Is it worth trying a little more camber? I have heard people comment on sorex needing a little more than some other brands - Not sure if its true or not.
#4835
Thanks Craig, I am running hole 3 front and hole 4 rear at the moment but Ill try 5 in the rear + have a look at all your other recommendations.
#4836
When you put steel gears in the 417 X diff do you sand thew to the right thickness ( Groskamp style)like we do with the plastic ones ?
#4838
Thanks a lot !
#4839
Hi Guys,
I'm new to the world of RC and I got 417 V5 arrived a week ago, but havent had time to build it yet. I prepared the Lower carbon fiber and that is it. I'm looking at putting savox 1251MG, Reedy lipo and Tekin RS pro set. Has anyone had setup like this before and if you do pls share your thoughts. enlighten me please, thanks.
#4840
Hi Guys,
Tekin is a great ESC for 17.5 and below. It can be a bit like a light switch with faster motors, though. You can also run a Silver Can with it, if you should be so inclined. Find someone local with a hotwire to get your software up-to-date and make sure you've properly configured it for the class you're going to race.
-Mike
#4841
Ive just noticed the front belt is fairly loose. Long shot here, but is it possible that was causing some of the tail happy behavior? Im guessing it would load up the rears before front tires under braking/accelerating.
#4842
Im not going to be able to get to the track for a few weeks so Ill ask the question here.
#4843
Hi Craig,
I need your precious help,
I run the trf417x in a small technical asphalt track with blinky 13.5, smokem fx chassis, on solaris medium. My car is very hard to drive and the only way to get tires in temperature is to go with four tamiya white spring, despite this in the two in line left-right of the track I always lose my rear end.
The only changes I've done from kit setup are 1B-1B in front with 0.5 anti-dive and 1XB-1D in the rear and I've rised the bulkheads of .5mm, so like the v5. In which way can I solve the oversteer?
Do you think I have to get a stiffer chassis?
Thank you for help.
Thank you for help.
#4844
Hi Craig,
Thank you for help.
Thank you for help.
Tamiya whites are an OK spring but I prefer Ride or HPI. To help get your tyres into the right operating temperature try different additives and higher temps on your warmers (~70c). If that doesn't work go lighter shock oil and a harder spring.
Also, your chassis is fine. In general I think people are way too quick to change carbon when their issues can more easily be solved with setup
#4845
Hi Craig,
Thank you for help.
Thank you for help.
