Like Tree4Likes
Tamiya TRF417
Old 06-08-2012, 01:40 PM
  #3196
Jochim_18's Avatar
Thanks...
Jochim_18 is offline
Old 06-08-2012, 09:27 PM
  #3197
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Jochim_18
thanks!! Which block should I use to narrow the track width of the car?
The blocks I consider must have
2 x 1 pc D
1 x split D
1 x 1 pc C
1 x split C
2 x split B
1 x split XA
1 x 1 pc E
CraigM is offline
Old 06-08-2012, 09:41 PM
  #3198
JoeyE's Avatar
Trader Rating: 45 (100%+)
I got my body for my TRF417 signed by Marc Rheinard recently.
JoeyE is offline
Old 06-10-2012, 12:45 AM
  #3199
svndayNZ's Avatar
Trader Rating: 20 (100%+)
I was wondering if somebody could help me I just bought some 1XA split suspension blocks, since I've installed them there is a lot of bind in the right hand side, the left is free flowing and fine. I can't get the sway bar to lift the right hand side, I've isolated the bind to these blocks. Since they are the same angle as the kit I didn't think I'd be having these issues
svndayNZ is offline
Old 06-10-2012, 08:29 AM
  #3200
Potoczak's Avatar
Trader Rating: 120 (100%+)
Make sure your hinge pin isn't bent slightly. I was having a similar problem. Put in a new hinge pin and problem solved.
Potoczak is offline
Old 06-10-2012, 07:02 PM
  #3201
CraigM's Avatar
If it's not the hinge pin then the block you took off may have been bent. I use .75mm spacers instead of 1mm behind the arm which gives you free movement and perfect play. Check too that your rear block is straight too, they go on crooked all the time and can cause binding, though most of the time I've found that it's the upright that binds.
Actually Jilles has a video on how he gets his suspension free
+ YouTube Video
CraigM is offline
Old 06-11-2012, 03:54 AM
  #3202
svndayNZ's Avatar
+ YouTube Video
Cheers, yea if spent another 2hrs completely re building the rear end. It isn't the hinge pin but something just isn't where it needs to be. Both hinge pins are straight with no bends at all. The other area I thought it might be would be the sway bar mounts as well. I need to replace those as I just snapped one. Ive only run one pack through the car with no prangs at all. Doing my head in a bit but thanks for the advice again Craig!
svndayNZ is offline
Old 06-11-2012, 03:56 AM
  #3203
thx for sharing
edwardcs is offline
Old 06-11-2012, 04:11 AM
  #3204
CraigM's Avatar
No worries, if you are running the kit wheelbase spacers then it will bind unless you sand the arms. If they are free then it's most likely the uprights which also sometimes need sanding, and if you have them right then it's one of the ball cups - either camber link or sway bars mounts. In about 4 years running tamiya I've only had one dodgy ball cup, so I'd focus on the arms and uprights.
So are you from NZ? I saw a cool track in Auckland which had a big race in Jan, I'd like to cross the ditch to race some time
CraigM is offline
Old 06-11-2012, 05:40 AM
  #3205
Can anyone please tell me where I can purchase (online) the split blocks....Tamiya's web site sucks to find them and I'm scratching my head trying to find another retailer....Thanks
NPETRO is offline
Old 06-11-2012, 06:07 AM
  #3206
2-Bad's Avatar
Trader Rating: 24 (100%+)
RC Market
RC Mart
RC Model
2-Bad is offline
Old 06-11-2012, 06:14 AM
  #3207
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
I wish my car would hurry up and arriveLooking forward to my first Tamiya
Yokomo_Ant3 is offline
Old 06-11-2012, 06:50 AM
  #3208
Originally Posted by 2-Bad
THANKS
NPETRO is offline
Old 06-11-2012, 10:09 AM
  #3209
Potoczak's Avatar
www.speedtechrc.com also carries all the TAMIYA blocks.
Potoczak is offline
Old 06-11-2012, 10:16 AM
  #3210
silverhkswrx's Avatar
I am in the market for a new TC. My TA06 is not carpet friendly. I am looking at the trf417x and wanted to know if anyone has ran it on carpet and how it performs...
silverhkswrx is offline
