Like Tree4Likes
Tamiya TRF417
Old 07-08-2011, 05:19 PM
  #1696
tamiya is using a new chassis? in the ets
oscargonzalez is offline
Old 07-08-2011, 10:06 PM
  #1697
crabboy's Avatar
Trader Rating: 58 (98%+)
Just built 2 of them up ready to try, one tip be careful when doing up the screws, the driver doesnt go very deep into the screw hex and it is easy to round out the hex, they even give you 2 spare screws, maybe in case you loose one
Rhys
Originally Posted by hacker
so whats the verdict on the tamiya 'white' gear diff compared to spec r's?
crabboy is offline
Old 07-08-2011, 11:33 PM
  #1698
Blueman Austria's Avatar
I think it is the original chassis, only shaped narrower in the fornt and rear after the suspension mounts.
This is still a prototype i think. Maybee done by themselfs...
Marc used this chassis already at the euro warmup here in austria.
Blueman Austria is offline
Old 07-09-2011, 04:38 AM
  #1699
TryHard's Avatar
More interesting is the front drive train, looking closely seems that Marc is using spring steel spool outdrives, and DCJ's... I assume from Spec-R.
Also has cut the V on the top dck at the front.. And split suspension mounts all round again. Looks like that car is setup to steer! Lol
TryHard is offline
Old 07-09-2011, 05:16 AM
  #1700
barts71m's Avatar
Trader Rating: 34 (100%+)
Think the are Roche outdrives, been released a week or 3 back. Very good ran them in my car last weekend for first time with 46mm driveshafts no wear and plenty of steering.
barts71m is offline
Old 07-09-2011, 10:37 AM
  #1701
syndr0me's Avatar
Trader Rating: 32 (100%+)
Motor screws are top/bottom on Marc's car with the 417 motor mount. We saw this at Reedy, too.
syndr0me is offline
Old 07-09-2011, 03:25 PM
  #1702
GMartinez's Avatar
Trader Rating: 91 (100%+)
Juhttp://www.rctech.net/forum/r-c-items-sale-trade/530993-tamiya-417-mint-extras.htmlst reposted this pkg local buyer backedout
GMartinez is offline
Old 07-09-2011, 03:32 PM
  #1703
Smile
Hi, can anyone tell me are the body posts in the same place as the 416x ?
in other words will my current body fit the 417,
thanks
U1timate PigDog is offline
Old 07-10-2011, 01:06 AM
  #1704
barts71m's Avatar
thanks
Yep 416/416X/417 use the same body mounts.
barts71m is offline
Old 07-10-2011, 04:54 AM
  #1705
VooDooPH's Avatar
Trader Rating: 18 (100%+)
pix?
VooDooPH is offline
Old 07-10-2011, 06:03 AM
  #1706
They have been running a cut top deck for some time now, front and back braces are cut, Elliot recommended this to us at the west London national
Smartypants is offline
Old 07-10-2011, 06:13 AM
  #1707
barts71m's Avatar
Just noticed that. Why have they gone back this way?
Also Marc running very short wheelbase in the front of the car. Very interesting.
Must be really working won the final ETS round.
barts71m is offline
Old 07-10-2011, 09:09 PM
  #1708
TryHard's Avatar
Actually, he's shifted all the weight forward.. Front wheelbase shim looks like 0.5mm (and Ackerman looks like 2mm, but might be less), whilst the rear wheelbase looks like 3.5mm. So all the arms back 0.5mm. Be interesting to see if he was running any front arm sweep as well.
TryHard is offline
Old 07-11-2011, 12:50 AM
  #1709
jonest's Avatar
In the last ETS meeting in Netherlands, I believe seeing Marc's setup sheet with B toe block on the Front Rear.
jonest is offline
Old 07-11-2011, 12:52 AM
  #1710
jonest's Avatar
wonder whether they cut the rear part as well, as pic was blocked by the deans plug.
jonest is offline
