Like Tree4Likes
Tamiya TRF417
Old 04-24-2012, 05:55 AM
  #3046
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by hana166
I can understand how difficult it is to face going back to doing shocks, retweaking when you only want to change the spur etc
Ed will regret this decision when he sees his first Australian track. The airbus700 is not the car for our conditions. It's ok, I have an old 416 I can lend him for nationals
CraigM is offline
Old 04-24-2012, 08:59 AM
  #3047
hana166's Avatar
hana166 is offline
Old 04-24-2012, 04:49 PM
  #3048
Quantra's Avatar
Hello RCTech, admittedly not a regular poster here but a regular reader. I was hoping to get some info on the 417X bearings...
I've been giving my 417X it's first full strip down and rebuild (since Jan) and noticed one of my rear outer wheel bearings is shot, the other getting that way and the two front outer wheel bearings are starting to feel gritty. All the other bearings are as smooth as when I first built the kit.
I remember reading in this thread that the 417X bearings are the best and they should out last the car and there is no need to upgrade them etc. So have I done something wrong here? Should I have been cleaning and oiling the bearings somehow?
Now is it worth trying to restore these bearings if it is even possible to do such a thing? If so how do I do it?
And what bearings should I buy to replace these ones. I'd rather pay out for something nice that will last a long time rather than cheap out on something that needs replacing often.
Oh and if it helps I race indoors only in 21.5T (beginner class) so I crash quite a bit but not too hard due to lower speeds. I'm not a great driver but I like to keep my car at it's best and take pride in my wrenching.
Thanks in advance for any advice =]
Quantra is offline
Old 04-24-2012, 05:45 PM
  #3049
syndr0me's Avatar
Trader Rating: 32 (100%+)
Bearings go bad all the time. Buy them cheap and replace them the second they don't seem perfect.
Qatmix likes this.
syndr0me is offline
Old 04-24-2012, 06:29 PM
  #3050
+1
stitchy is offline
Old 04-24-2012, 07:06 PM
  #3051
maxepower's Avatar
Talking preping carbon pieces!
Originally Posted by Guillermito
Hello, I wonder whether to put CA on the edges of carbon parts.
Thank you very much. Best Regards.
I use q-tips as an applicator, definitely round the sharp edges, I use emery cloth, don't forget to round the slots where the battery tape goes through! Then apply the CA, make sure to do it in a well ventelated area, the fumes can be overwhelming! Better safe than sorry!
Just my 2$
maxepower is offline
Old 04-25-2012, 12:35 AM
  #3052
TryHard's Avatar
haha, if it gets that bad.. well... hisssss
TryHard is offline
Old 04-25-2012, 11:40 AM
  #3053
Quantra's Avatar
Thanks for the advice. I'll see if I can pick up a bucket load on ebay for cheap =]
Quantra is offline
Old 04-29-2012, 08:13 AM
  #3054
Trader Rating: 23 (100%+)
And what brand bearings do you guys propose? And do they come as a packaged 417 kit? I've got 2 or 3 that needs more attention than the rest. New ones would help a lot.
R_T_L is offline
Old 04-29-2012, 10:49 AM
  #3055
I typically just buy clutch bearings for 1:8 off-road. They are a lot cheaper than "true" Tamiya or Xray bearings, and they are often the same size. Just get those with oil instead of grease.
Nilks is offline
Old 04-29-2012, 03:06 PM
  #3056
CraigM's Avatar
I use the arena ceramic bearings from rcmarket. They are cheap and last a long time
CraigM is offline
Old 04-30-2012, 04:39 PM
  #3057
Guillermito's Avatar
In the servo direction should not put the rubber screw? the manual does not show it, but it is not normal...
Thanks. Best Regards.
Guillermito is offline
Old 05-01-2012, 12:36 AM
  #3058
CraigM's Avatar
Do you mean the rubber bushes? They should not be used, the servo should be fixed directly to the mounts with no flex
CraigM is offline
Old 05-02-2012, 07:42 PM
  #3059
CraigM's Avatar
Update on my diff, I've now got 20+ runs on it with 4.5t and 5t motors and it is still butter smooth. I refilled it once because I'm getting a little leakage through the orings but none through the gaskets. I actually opened it again the other day because it felt so light I thought it had no oil in it but it was completely full
There is little sign of wear on the gears and the backlash is still good, so this seems to have fixed all of the issues.
CraigM is offline
Old 05-03-2012, 01:56 AM
  #3060
Blueman Austria's Avatar
Default CSO lower decks
Hy there!
Anybody tried the CSO lower decks wich are available for the 417?
They look like the 417x lower decks, but are nearly half the price.
So how is the quality of them compared to the Tamiya original ?
Greetings Rainer
Blueman Austria is offline
