Tamiya TRF417
#1651
Unfortunately the rules for this season (in Denmark) is 7-minute-heats. It really is tough for the equipment.
#1652
It very much could be the tires - Our tires are only really good for 1 run (in modified - stock can get 2-3 runs) and then degrades fast. What would you suggest to do?
The thing you could do is to not warm the tires before the run, try to make a setup to keep the tires temp on all the tire, not only the inner or outer. Try less camber (1,5°), less toe and less camber change.
#1654
Hi
I wonder can you use the Sakura zero diff pulleys on the 416 / 417? As that's going to give a FDR of 2.0 for the 417 as they are 38t
Ta
Ta
#1655
417 Gear Diff Lube
Hi, Just got the new Tamiya Gear Diff II (White)
Does anyone know what viscosity oil comes in the kit. All it says is Tamiya Damper Oil. It looks pretty thin maybe 1000 wt?
Has anyone used this oil and does it leak?
#1658
#1659
ran mine (ver2 gear diff) with 1000wt oil and it worked fine... very minimal leaking near the outdrives (especially when compared to my spec-r gear diff that couldn't hold anything in except for putty). will try with 800wt oil and see if i can get more corner entry speed
#1660
Off topic here.. I have two TRF417 custom cut chassis protector film for sale in the for sale forum if anyone is interested. http://www.rctech.net/forum/r-c-item...protector.html
#1662
Gear Diff II Build
Thanks for the responses, how about the build? Are you putting it together as Jilles says a few posts back. Sand tabs off and use three washers?
