Tamiya TRF417
#1801
Just posted some pictures of Jilles Groskamps car from the 2011 EFRA Touring Car Euros at www.EFRA.ws. All the team are running a slightly different setup. If you've got any questions, follow me on Twitter @RCRacingOli and I'll try to get an answer to any question from the team
Can't get to twitter (damm chinese firewall), but could you check with the guys what their running wheelbase wise? Looking at the Rd5 pics of Marc's car, looks like cut top-deck and split blocks again... but the front wheelbase/ackerman looks almost like it's on 0mm! Have a look at Jilles' too please
#1802
Hey Oli,
#1803
Here is the set-up sheet link.
http://thercracer.blogspot.com/2011/...ing-sheet.html
I'm still playing with springs etc atm, but its really getting there. I did get pretty frustrated at one point, and think of getting a 3mm chassis made for carpet, but the car is going pretty well now.
#1804
#1805
no problem, as I say, with teh springs I am switching between white and blue at the front atm, I think Blue seems to give me a little more steering, but I am rolling a little more than I would want on the high speed corners.
#1806
Rheinard is the 2011 European Champion !!!
#1809
I did a blog post about some of the 417 chassis changes with pictures here
http://thercracer.blogspot.com/2011/...dates.html?m=0
#1810
And I bet more than anything the vertical motor screws are to making meshing the motor easier... with the horizontal ones, the motor moves during tightening of the mesh, making it difficult to mesh right (IMO).. so I bet Marc has changed it to make it a bit easier :P
don't forget they are running rubber's so quite a bit different to foams (in reference to the comment about flex).
Actually, the Tamiya chassis plate is particularly flexie anyway, due to the way the carbon is laid up. it's mostly all 0/90 fibre orientation, with no ±45. Hence it's very stiff longitudinally, but also flexible in torque (twist).
The changes made to the car are pretty much about adjusting the balance at certain points of the car. The cut top deck really isn't as big a change as you would expect, and neither are the suspension blocks. You make a change to the layup of the chassis plate, it will affect the whole thing, not just the areas they are looking at. Not saying it's perfect, but gives an idea of why this way rather than changing materials
#1811
Anyone have a setup for IIC last year using 417(was it out)?
Just curious as I will be going for the first time and want a decent base setup.
Modified setup is fine but I will take a decent 17.5 setup as well.
#1812
I think you will see split blocks on the car with Jilles snowbirds setup as the starting setup!
#1814
the new chassis mods looks similar to the "Smokem 416 FX chassis" , similar cut outs
#1815
