Like Tree4Likes
Tamiya TRF417
Old 05-28-2011, 02:29 PM
  #1486
Originally Posted by Jack2
running the diffs/spool in the higher position changes the drive shaft angle and changes the roll charactoristrics etc and something I have been wanting to try.
Aaah flipping like that. I thought you were going to swap the belts around, so the front belt was on the electronics' side and the rear belt on the battery side.
Nilks is offline
Old 05-30-2011, 02:01 AM
  #1487
kentech's Avatar
TA06 gear diffs but the 417 one will be very similar, just 37T instead of 39T.
kentech is offline
Old 05-30-2011, 08:32 AM
  #1488
GeorgePravata's Avatar
Trader Rating: 171 (100%+)
Need some help here with 17.5 blinky no boost what would be the best or a very good starting point for gearing a D3 17.5. Thanks George
GeorgePravata is offline
Old 05-30-2011, 08:38 AM
  #1489
Trader Rating: 88 (100%+)
hey george, this weekend at jackson i ran a 3.5FDR on a Duo3..
joey is offline
Old 05-30-2011, 08:44 AM
  #1490
Yeah i was there also. What was your temp.
Old 05-30-2011, 11:15 AM
  #1491
entitymugenmtx's Avatar
Trader Rating: 85 (100%+)
Anyone looking for TRF417 PARTS NEW PM ME OR CHECK OUT MY POST I HAVE MORE COMING
entitymugenmtx is offline
Old 05-31-2011, 09:06 AM
  #1492
John.C's Avatar
Trader Rating: 37 (100%+)
George - 3.35 - 3.45 FDR would be a good starting point. My temps after each run was in the 145 - 155 range using the same motor (D3). I didn't lack any speed down the straight and had decent punch in the infield. Along with chassis setup, I plan on testing different gearing and physical timing on the motor the next time I make it out to Jacksons. Hopefully, I'll see you on the 18th.
John.C is offline
Old 05-31-2011, 02:21 PM
  #1493
Just got in the TRF Large spring retainers
stitchy is offline
Old 05-31-2011, 05:30 PM
  #1494
Default Spec-R Gear Diff Build Question
Guys:
How important is it to ensure that the tabs on the diff housing are aligned?
First gear diff was a Tamiya one and the instructions did not specify to ensure that the tabs are aligned, whereas the spec R diff instructions specify it.
Would the diff be more prone to leakage if not aligned? any experience would be appreciated.
Thx!!
mhavlena is offline
Old 05-31-2011, 10:07 PM
  #1495
Tron's Avatar
Trader Rating: 17 (100%+)
Can anyone with Marc Rheinard and Victor Wilck's contact info please ask them to post their setup sheets from the Reedy Race?
Congrats to Marc and Victor 1-2 sweep of the mod invitational class!
Tron is offline
Old 05-31-2011, 10:25 PM
  #1496
kedal's Avatar
Yes, I want it too !
What was the grip in the reedy race ?
kedal is offline
Old 06-01-2011, 05:06 AM
  #1497
ldivinag's Avatar
so... got my 417 tonite (*super duper price).
took about 10 hours. and still not complete but got about 80% done.
now, about the steering. looking at the manual, step 8 page 7.
1. shims are silver and spacers are blue anodized, right?
2. right now, without a servo and just moving the steering by hand, the 2 screws BA1 that goes into steering bridge BB20 will loosen up after a few cranks. if i tighten them down, it binds. it seems that there needs to be a shim on the top, not just a the bottom of BB20... right?
thanks... now for sleep... lol...
one more thing... no other way to mount the battery besides using tape (either double sided or actual batt tape)???
ldivinag is offline
Old 06-01-2011, 09:53 AM
  #1498
Trader Rating: 32 (100%+)
Originally Posted by stitchy
Stitchy! You got PM....
ittjv is offline
Old 06-01-2011, 10:35 AM
  #1499
They're cars were box stock with exception of hpi silvers all the way around and double gear diffs. Victor told me 500,000 front and never asked for the rear diff oil.
Juan Aveytia is offline
Old 06-01-2011, 10:56 AM
  #1500
PM'ed ya back
stitchy is offline
