Team Associated TC6 Thread
#6587
Damn Associated. Please fix the stock on the regular parts. All shops are out of stock. :S Continueing for a while now, drives me nuts.
#6589
Before you buy a new motor, try a gear ratio down around 4.2. That's pretty safe for racing, but I'm not sure about bashing, so watch the temps. With a ballistic, you might be able to go even lower. 5.0 is pretty far off for a 17.5 without boost. Also, you can look at increasing the timing on the motor, as that makes a big difference.
-Mike
-Mike
#6592
Dual bell crank for 6.1
Getting requests for a drop in dual bell crank for the 6.1
Good timing... We are testing a prototype and may go production on it. Stay tuned on our thread.
http://www.rctech.net/forum/electric...des-tools.html
#6593
https://reflexracing.3dcartstores.co...s_c_4-1-3.html
Ed
#6594
-Mike
-Mike
I expect to be going about 40ish mph with a 10.5 and 5.3fdr. With the 17.5 my ESC wasn't even warm.
On a side note, I have the older GTB purple heatsink ESC and the guy I bought it from said he put it in "blinkymode" () to limit it's speed for technical carpet racing. But I'm looking over the insturctons and setup manuals and I don't see anything he might be referring to. As far as I can tell I don't think it even has a current limiter.
http://www.teamnovak.com/products/esc/gtb/index.html
#6595
Cristian from Reflex racing is supposed to be getting some alloy ones up for sale today/tommorrow
Ed
Ed
#6596
I have a second chassis and i would really like to give it a try.
#6597
A gear diff in the rear would be a nice first addition (and some of the Reflex soft shock bladders) but it will be absolutely fine as-is. Get a good setup on it and go from there.
#6598
#6599
#6600
