Team Associated TC6 Thread >
Like Tree20Likes
Old 08-24-2012, 08:04 PM
  #7336
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Originally Posted by losi888
Is that 1mm shim in front (in front of a arm) and 1mm shim in the rear (on the back side of a arm).
Yes
geeunit1014 is offline
Old 08-24-2012, 08:19 PM
  #7337
KHoff7's Avatar
Originally Posted by geeunit1014
Yes
Agreed
KHoff7 is offline
Old 08-26-2012, 08:43 AM
  #7338
What is a good gear ratio to start out with for vegas sized carpet track. Running 17.5 trinity D3.5 timing turned up. Thanks.
losi888 is offline
Old 08-26-2012, 04:04 PM
  #7339
racer x 1's Avatar
Trader Rating: 27 (100%+)
Default Tek 6
So after another long day of trying things and driving I think ive finally got my car on pace for my local 17.5 blinky class. it turns out short camber links and a high roll center was key as most of you suggested. Thank you.
racer x 1 is offline
Old 08-27-2012, 01:11 PM
  #7340
bhambrent's Avatar
Congrats to Rick Howart for his tc mod win.
ROAR Electric On Road Paved Nationals
1-10 Touring Modified
Driver Name (Q#)A1 Points Total
Hohwart, Rick (1) 100 (1=24/6:10.374) 100
Lemieux, Paul (2) 99 (2=24/6:14.961) 99
Hebert, Keven (3)98 (3=23/6:01.882) 98
Cochran, Sean (997 (4=23/6:10.023) 97
Alexander, Aaron (5)96 (5=23/6:11.468 96
Hardman, Andrew (4)95 (6=23/6:12.394) 95
Erchinger, Ethan (7)94 (7=23/6:14.615) 94
Jucha, Brian (8) 93 (8=22/6:01.641) 93
Evans, EJ (10) 92 (9=22/6:17.410) 92
Vik, Tyler (6) 91 (10=11/2:49.483) 91
bhambrent is offline
Old 08-27-2012, 02:10 PM
  #7341
ekim628's Avatar
Congrats Rick!!! AKA Mr. Reedy Man
Now can you post your kick-ass setup for all of us
Eric-
ekim628 is offline
Old 08-28-2012, 11:04 AM
  #7342
Rick Hohwart's Avatar
Eric-
Thanks!
Here it is!
Hebert ran almost identical and this is very close to Juho's World's setup.
Rick Hohwart is offline
Old 08-28-2012, 11:26 AM
  #7343
rosko's Avatar
Any one using the exotek conversion? What differences did you feel on the track between the stock and exotek conversion
rosko is offline
Old 08-28-2012, 02:06 PM
  #7344
Hi Rick!
Can you post pictures of car?
Thank you!
edit: can you share hpi silver spring LBS rate?
btw, lipo has connectors, they are in rear or front ?
M.Abramowicz is offline
Old 08-28-2012, 02:20 PM
  #7345
R Doyel's Avatar
Originally Posted by Rick Hohwart
Thanks!
Here it is!
Rick, thanks for posting this. I'm anxious to try it. I'm a little confused on the springs, though. What would be an equivelant to the HPI silver, in RSD or Associated? I tried doing the math on the rating and it came out to like 8 lbs/in. Is that right?
Thanks, Ryan
R Doyel is offline
Old 08-28-2012, 02:37 PM
  #7346
CristianTabush's Avatar
HPI Silver are roughly equivalent the new RSD Purple Spring. They are rated by HPI at 16.9lb springs.
From our tests, they are slightly stiffer than the RSD Red, and softer than AE blue. This is where the purple spring falls.
CristianTabush is offline
Old 08-28-2012, 02:43 PM
  #7347
R Doyel's Avatar
Thanks, Cristian. I figured my math had to be wrong
Look for an order from me
R Doyel is offline
Old 08-28-2012, 07:47 PM
  #7348
wtcc's Avatar
Thanks!
Here it is!
My IPad 3 always opens the AE setup sheets without the filled fields Does someone know how to solve this?
wtcc is offline
Old 08-28-2012, 08:00 PM
  #7349
evochick's Avatar
I can see me getting flamed for this
Adobe on Android works fine, can you install Adobe on an Ipad ??
This is coming from someone whe does not own and never will buy a product from Apple.
Beth.
evochick is offline
Old 08-28-2012, 10:31 PM
  #7350
racer x 1's Avatar
Beth.
"theres an app for that" no really you can dwnload the adobe app for apple products....
