Team Associated TC6 Thread >
Like Tree20Likes
Old 10-21-2011, 11:22 AM
  #4291
Geberit's Avatar
Originally Posted by JamesL_71
What front hexes fit the TC6? Im looking for offset hexes to space the front wheels a bit.... Id prefer not to use the 1mm disc spacers.
I see that some of the factory guys are using what appears to be some sort of black plastic hex on the front. Anyone know what part this is?
Because the original CVD's front are replaced with HPI double joint CVDs to avoid chattering and the original hex's don't fit. Many racers drive them.
Geberit is offline
Old 10-22-2011, 07:46 PM
  #4292
Midnight's Avatar
Trader Rating: 87 (100%+)
I was down at Mikes Hobby this weekend and watched a full heat of sedan and a good friend Steve Breuer is running a xray 2011 sedan on a carpet track. I say all that to ask this, is the tc6 as quite as the xray 2011. You couldnt even tell the car was running unless you were looking at it. Im a ae fan thru and thru and would like to stick with ae but all the guys there run the xray so setup would be an ease. Im really leaning towards ae. THanks in advance. ALso what all extras will I need for the tc6, ie sway bars, bumpers, I also read the the front end was fragile on the tc6.
Midnight is offline
Old 10-22-2011, 10:22 PM
  #4293
Trader Rating: 77 (100%+)
I love my TC6. I will only comment on the front end. It is NOT fragile. I hit a lot of things and it has been bullet proof. Coming from a TCX it is way easier to drive as well.
goin2drt is offline
Old 10-22-2011, 10:24 PM
  #4294
Midnight's Avatar
Thanks bro.
Midnight is offline
Old 10-23-2011, 02:47 AM
  #4295
Ariel Reds's Avatar
Hello TC6 Family!
im from malaysia, and just started using this kit and it is awesome!
but one thing i want to ask, how can i buy the dial grip? anyone can help me? inbox me the step and payment method that available!
cheers
Ariel Reds is offline
Old 10-23-2011, 03:11 AM
  #4296
Originally Posted by Ariel Reds
Hello TC6 Family!
cheers
Here is the site:
http://www.ppdbillet.com/dial-a-grip.htm
look at this too:
http://www.reflexracing.net/110th-Touring_c_1.html
olly986 is offline
Old 10-23-2011, 06:12 AM
  #4297
Chief's Avatar
Trader Rating: 14 (100%+)
Does anyone have HPI part numbers?
Chief is offline
Old 10-23-2011, 06:41 AM
  #4298
Trader Rating: 118 (100%+)
Are the new TC6 kits coming with the new AE spool and gear diff?
Chris Furman is offline
Old 10-23-2011, 07:09 AM
  #4299
Geberit's Avatar
Try here ...
http://rcmarket.com.hk/product_info....ducts_id=10680
http://rcmarket.com.hk/product_info....oducts_id=6465
Geberit is offline
Old 10-23-2011, 07:18 AM
  #4300
Midnight's Avatar
So does anyone have any knowledge to how loud the cars are.
Midnight is offline
Old 10-23-2011, 07:38 AM
  #4301
Buckaroo's Avatar
The better your gear lash and parts condition, the quieter the car will be. ANY car.
Get some board hits, some worn bearings, and some rock dings on your spur/pinion and ANY car can sound like a Mad Max reject.
Buckaroo is offline
Old 10-23-2011, 04:01 PM
  #4302
hnasdad's Avatar
Okay, so I'm two weeks away from carpet season starting, build is complete....round of extra parts purchased......Body painted, waiting to be cut and mounted.....looking at gearing now. Ive searched this forum understand FDR, but what I dont understand is.
WHY IS IT SO HARD TO FIND A SPUR/PINION FOR THIS THING?
Associated carry's TWO spurs per thread pitch....TWO? Come'on now.
So, im headed to Xray to find a spur, but no pinions.....back to tower, robinson racing,no spurs, and pinions are too small, RW is shipped out of the states at lefthander but they dont have anything, Xenon's website looks like a elementary school build it. And now Im back to Xray?
According to Novak's website im starting at a 3.5 FDR for 17.5 non boosted. Im sure that Im going to be able to go up, but dont want to be stuck at the track without the correct gearing, and options to go up or down. So, im looking at scabbing together from several different websites enough to have some adjustment.....
Im looking at the gear chart from this forum as to what fits and what doesnt and I cant belive it takes this much to get this thing geared right, or close.
96/50 so says Maybell....96/50 it shall be....3.84 with no adjustment, hope it works on my track
DONE!
It gets better, a 96/50 from xray.....10 dollars in shipping for a grand total of 31.00 for one spur one pinion.....sweet
hnasdad is offline
Old 10-23-2011, 04:07 PM
  #4303
Trader Rating: 88 (100%+)
hksrc.com has the 3 racing pinions if you're going 48 pitch, they are very nice. The 69-tooth Kimbrough spur works great and allows you to go down to a 3.45 with a 40 tooth pinion. Though I'm using a 36-38 at my local track.
tcdrvr2 is offline
Old 10-23-2011, 04:09 PM
  #4304
Buckaroo's Avatar
Use Kimbrough 96 tooth 64 pitch for blinky, and get used to the idea of using different screw holes to hold the motor in. Works just fine, trust me, I've hit everything that there is to hit, often at full speed, and never had a motor come loose or slip in this car.
Seems one big epic fail on AEs part was focusing spur selection on Boosted/Mod classes.
Buckaroo is offline
Old 10-23-2011, 07:19 PM
  #4305
Chaz955i's Avatar
I'm using a Kimbrough 100t 64p with no issues. No motor movement either. Not sure what the big deal is about finding gears for this car.
Chaz955i is offline
