Team Associated TC6 Thread
#3527
#3528
will the new gear diff fit on the tc5?
#3530
Went is the gear diff is coming out
#3532
If you read above posts, it is expected mid Sept to mid Oct
#3533
mod motor 4 sale
If anyone runs mod, I have an LRP Vector x-12 4.0 motor for sale. Run a few times, never overheated, and cheap. Hardly used since all they run is stock around here.
http://www.rctech.net/forum/r-c-item...x12-4-0-a.html
#3535
wouldn't you get an issue with width to fit? I have never tried to swap them thought...
#3536
for rear camber link, how do you guys fit 1-6 hole on tower also fit inner hole on rear hub/carrier?
i tried screw turnbuckle all the way in and it still give me positive camber
#3538
It would be a good idea to purchase a few different length turnbuckles as different setups will require different lengths. You will find having at least 2 different lengths will go a long way for most setups. Buy at least 2 of each. Associated makes several that will fit the TC6.
