SXX Comp and TC Version 2
#331
SXX TC V1 NOT WORKING
Hi I WAS WONDERING IF ANY COULD HELP ME i HAVE THE SXX TC V1 AND ATM TO GET IT TO WORK I HAVE TO TURN THE MOTOR BY HAND TO GET IT TO START UP. I CHANGED THE MOTOR TO MAKE SURE IT WAS NOT THAT BUT IT STILL DID IT HAS ANY ONE ELSE HADE THE SAME PROBLEM ANY HELP WOOULD BE GREAT.
#333
#335
Anyone know what breaks in the esc when you switch polarity on the battery?
I have had two die on me over such a mistake and are now hoping i could bring new life to them with the upgrade-kit (http://www.lrp.cc/en/products/new-pr...egler/details/)
I assume it's the bec that is defect, and so i think this will solve it. Can I check if it truly is the bec that's broken in any way?
#336
Nice that they didn't make the original LRP Bridge work with the upgrade kit, and I suspect the Flow.
It truly is nice that they are offering this...what's the price?
#338
#339
Try another USB port to recharge USB pool in windows.
#340
I did try two ports last night, but I guess I'll try another separate one later today. Thank you for the suggestion.
Any other ideas? If there's one thing that I hate about LRP it's their complete lack of troubleshooting & support.
#341
Anyone with the new board in a TC Stock Spec, how are the brakes?
I notice when I run lower FDR's the brakes get very light and soft in blinky 17.5 TC.
I can't run a smaller spur than 64p 96 so once into 45+ pinions the brakes get less and less.
I've swapped out everything to see if it's electronic, but it seems to be a low FDR issue in my old TC5R.
Can't wait to get my SXX's back.
#343
i have a ssx tc version 2 which i believe has a faulty bec, when i pull full throtle with 7.4 buggy or tc it turns off, is this correct?
if yes, could i use it or will it work fine with 1 cell lipo 1/12th scale???
cheers
cheers
#344
Can you sent me the link for my LRP SXX SS and TC
I wanted to up dated my esc from 1.5 version to to 4.0 [email protected]
#345
Hi Sean
All of the updates are available at LRPs website.
http://www.lrp.cc/en/service/software-update/
