SXX Comp and TC Version 2
#316
Hi everyone,
I have just bought a used Nosram Pearl evolution V2 that came with the firmware 3.0. I am looking for the manual of this firmware as the programs are quite different from the manual that I have found in Nosram website.
I'm also sufering a problem, the esc stops after 5 or 6 laps, the motor and the esc are cool, around 35ºC, ambient is around 10ºC. I can move the steering, but the motor doesn't work. In the esc the red and blue light are alternative on. What is happening?
Kind regards
Javier
ps: motor corally red series 9.5T; ratio 6.67;big TC track
Kind regards
Javier
I think if you down load the firmware you should get the manual as part of the zip file.
Good luck.
#319
I change the sensor lead and it was no difference. Ok, i will try the expensive option, buying another motor.
Cheers
javier
#321
#322
#323
Can someone help me out. I have bought a SXX but didn't get the stock version by mistake as i run 13.5.
Is there actually any difference?
#324
#327
This weekend I tried some changes with my Nosram pearl evolution 2, I remove the lipo cut-off and everything started to work, I can finish 7 min runs without problems, but I am not happy running without the cut-off. Has anyone suffered the same problem??
Regards
javier
Regards
javier
#328
Can somebody share their ESC set up, using TC Spec V2 and X12 4.ot motor (not octawind ) in a TC car?
One more thing, mine has not been updated to v4 firmware, whenever I set 'FEEL' to below value 5, it looks like its limiting the the top speed, does 'FEEL' value affect top speed too?
What are the differences from the out of the box firmware compare to the updated v4 firmware. My friend told me instead of having 10 value steps the updated one has only 6 value steps. Is this better?
#329
Out of the box most LRP's are sent with version 1.5.. this as you say has 10 profiles for feel
Feel has torque limiting profiles under 1.5 and 4 which are designed for x12 motors.
Personally version 4 is much better feel and brakes, would advice on the upgrade
Once on version 4 8FDR with a 4t feel 2 (45% torque Timing) and boost 2 (29%) which should be more than enough
If you move to Boost 3 that is 33% boost and to be honest my car becomes un drivable just has way to much power specially a none OCTA motor
This is a starting point shall be different depending on the track
#330
