Spec-R Gear diff review >
Old 09-08-2010, 05:16 AM
  #526
Dispite a lot of comments in this thread regarding leaking I would like to point out that a correctly designed gear diff put together correctly will not leak and they will last almost forever. Such as kyosho, mugen Tamiya gear diffs which I have used in the passed with zero leaking issues
Whilst from a ease of maintance perspective I would rather a gear diff I have to admit when I change rear suspension settings I will also be doing so with an adjustment of the a ball diff which just isn't feaseable with a gear diff in a lot of circumstances between runs
Combined with non ease of adjustment and the added roational mass I am not convinced using a gear diff and in class other than mod will be better.
frozenpod is offline
Old 09-08-2010, 07:17 AM
  #527
M-Technic's Avatar
Trader Rating: 15 (100%+)
That's why you buy multiple gear diffs and build them with different oils
M-Technic is offline
Old 09-08-2010, 11:38 AM
  #528
R/C Tech Elite Member
JayL's Avatar
umm have you weighed them
my nt1 diff with capricorn gears weighs 2 grams more than my stock diff, feel that
JayL is offline
Old 09-08-2010, 01:02 PM
  #529
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
BlackedOutREVO is offline
Old 09-08-2010, 01:21 PM
  #530
Trader Rating: 27 (100%+)
So can you use a nt1 diff for a t3??...I read something like that before but cant remember where. I would rather go that route then spec r
mist467 is offline
Old 09-08-2010, 01:30 PM
  #531
Yes you can. Ive made 5 of them so far lol, its not to hard to mod to work
Old 09-08-2010, 01:36 PM
  #532
Skiddins's Avatar
....Such as kyosho, mugen Tamiya gear diffs which I have used in the passed with zero leaking issues
Whilst from a ease of maintenance perspective I would rather a gear diff I have to admit when I change rear suspension settings I will also be doing so with an adjustment of the a ball diff which just isn't feasable with a gear diff in a lot of circumstances between runs
Combined with non ease of adjustment and the added rotational mass I am not convinced using a gear diff and in class other than mod will be better.
You're talking about 1/8 gear diffs, which have to handle slightly different power and weight ratings etc.
There isn't much difference in weight between a ball diff and the gear diff (6g on my T3) which is less than the difference between the one-ways and spools etc that people used to change between (without thinking twice).
The difference in drive out of a corner, and especially off the line in a final can be staggering, although you do have to change the driving style slightly due to the extra grunt out of corners which can unbalance things if you're not careful.
Skiddins
Skiddins is offline
Old 09-08-2010, 01:39 PM
  #533
BlackedoutRevo mind filling me in on whats needed? Or if there is a write up somewhere. Just want to make sure i have everything i need so i can try it this weekend. Thanks
mist467 is offline
Old 09-08-2010, 03:11 PM
  #534
billjacobs's Avatar
Trader Rating: 65 (100%+)
Default 3 racing gear diff assembly
when assembling the 3 racing gear diff, seat the rubber gasket into the pulley side. This should fix the wobble. You shouldn't overtighten the 2 sides together.
billjacobs is offline
  #535
Skiddins
They were all 1/10th diffs and at least with those diffs there was a difference in weight but then again they were well made didn't leak or chew up gears which it sounds like this new range of TC gear diffs are very marginal most likely in an effort to save weight.
The Tamiya in particlar came with a stock gear diff and the ball diff was an optional hop up. I switched both ways a few times which is one of the reasons I ended up with the opinion and comments above.
Re more drive out of a corner I have not experienced this from switching the the tamiya car from gear diffs to ball diffs then back to gear diffs. The only difference I have noticed is there is additional friction before the diff slips (not noticeable on track) with a gear diff as more force is required to overcome sticktion of the seals and oil.
Old 09-08-2010, 03:13 PM
  #536
JayL's Avatar
http://www.rctech.net/forum/7121865-post1660.html
http://www.rctech.net/forum/7120864-post1653.html
BOR's look waay better
JayL is offline
Old 09-10-2010, 07:10 PM
  #537
Satish's Avatar
Hey Guys,
Sorry to change topic, installed the Gear diff in my xray 009 EU, with 52mm drive shafts.
Seems that the shafts butt up against the inside of the diff?
Do i have to get shorter shafts for the rear, i cant get the upper link to scre into the rear hub?
Any ideas??
thanks
s
Satish is offline
Old 09-10-2010, 08:18 PM
  #538
you should use 50mm shafts when using spec-r gear diff.
hardmankam is offline
Old 09-10-2010, 11:14 PM
  #539
Originally Posted by Satish
Hey Guys,
Any ideas??
thanks
s
Or space the lower rear roll centres out buy .075 per side
This is what i did
sidecarphil1 is offline
Old 09-11-2010, 05:45 AM
  #540
kschu's Avatar
Trader Rating: 16 (100%+)
Hey Guys,
Any ideas??
thanks
s
u need this
kschu is offline
