Spec-R Gear diff review >
Old 08-12-2010, 12:58 PM
  #436
RC MARKET's Avatar
MOD. XRAY NT1 Rear Gear Diff. bester than 2 !
but little expensive than this 2 brand name .
RC MARKET is offline
Old 08-12-2010, 09:00 PM
  #437
dodo's Avatar
Originally Posted by oldrcr
Hi,
has anyone run both and have an opinion which one is better?
I know there is a weight difference, even the different diameter makes a difference when it comes to rotating mass, but are there construction differences, beside the obvious size difference, or durability comparisons?
Thanks.
sorry for being off topic....
i can't get hold of spec-r gear diff for my 416X at the moment cos it's out of stock. but my LHS just rec'd shipment of u-pro gear diff for photon. my question, will this fit 416X? sorry if it's been covered before. many thanks
dodo is offline
Old 08-12-2010, 11:33 PM
  #438
Damon's Avatar
Originally Posted by yokemad
My one also Leaks both Around the Pulley and near shafts...
there should be big O ring around the pulley to seal it and maybe better o rings around shafts...
for leaking around the pulley try a small amount of transparent silicone on the plate near the step:
when reopening the differential silicone comes off well without leaving a trace
instead for leaking near shafts we have to wait the new o-ring from Spec-R, at the IFMAR World Championship they provided the TRF Team with a new transparent o-ring
Damon is offline
Old 08-13-2010, 12:42 AM
  #439
Tor Erik's Avatar
RC MARKET , if you run NT1 diff in the Tamiya 416, what pulley do you use ? the stock Xray 38 T ?
Tor Erik is offline
Old 08-13-2010, 04:56 AM
  #440
Skiddins's Avatar
You'll never get rid of the leaking completely, just like shocks, they will eventually need rebuilding as well.
Sounds like the new O-ring will help, and perhaps a thin, round, very large O-ring closer to the outside, like a 1/8 gear diff might help a lot more than the cardboard gasket that is currently used.
Skiddins
Skiddins is offline
Old 08-13-2010, 07:02 AM
  #441
jag88's Avatar
I thought this was the new o ring ?
jag88 is offline
Old 08-13-2010, 08:14 AM
  #442
yokemad's Avatar
I've managed to stop leak around shaft area only leak comes around pulley I ll try that tip to stop that thanx for the info...
P.s muchmore slime over o rings stopped all leak
yokemad is offline
Old 08-13-2010, 12:20 PM
  #443
I've just ordered my spec-r gear diff for my TRF416X, but i've been reading a lot about diff oils.
I just don't know were to find some of these diff oils and i even don't know what would be a thicker oil.
The higher the number or lower the number?
I know that tamiya has diff oils of 5000, 10000 and 30000 but wich one is a thicker oil?
Can someone help me out with this mather?
Kind regards
addicted2blue is offline
Old 08-13-2010, 12:25 PM
  #444
jonest's Avatar
Kind regards
I'm using XRay 2k and 3K oil.... works ok so far.
jonest is offline
Old 08-13-2010, 12:27 PM
  #445
JCarr's Avatar
The higher the number the thicker the oil. The real headache come in though with all the different rating types, WT, cst. There is no real standard so you have to pay attention to which type someone is referring to. Hope this helps, some atleast.
JCarr is offline
Old 08-13-2010, 03:34 PM
  #446
Three's Avatar
How does a thicker oil (higher CST) react compaired to thinner oil? What is a good starting weight for 17.5? (1000 CST?)
Three is offline
Old 08-13-2010, 04:02 PM
  #447
RC MARKET's Avatar
3 Racing released Sakura Zero 37/38T gear diff. maybe fit for TRF416 !
38T pulley for XRAY T3 !
Old 08-13-2010, 05:45 PM
  #448
cheehtae's Avatar
Trader Rating: 15 (100%+)
try it in and let us know.
cheehtae is offline
Old 08-13-2010, 08:46 PM
  #449
kschu's Avatar
Trader Rating: 16 (100%+)
Good news !
Spec-R X ring available now to prevent leaking ...
please visit KS Hobby now.!
kschu is offline
Old 08-14-2010, 01:32 AM
  #450
Tor Erik's Avatar
YES , please let us know if this will fit in the 416 :-)
I want to use it for Mod !
Tor Erik is offline
