Losi XXX-S
#7921
go to losi' website, i'm guessin u'll be running at Road rage or trackside, an i know there is one good setup, i think it's hodge's, check the tire info on the sheet to make sure.
#7922
yea i race at trackside, and ill have to check there asap,,,
at the monent im running 40wgt oil all around, purple/silver, swaybar in the front, take-off 27,5mm ride height all around. 3 droop front,4 rear,off-set rear hubs, 4 degree blocks front,camber is what ever is was set when built, fron shock are all fartest out in front and farthest in for rear.low rollcenter blocks dont remeber what the kickup is. but other wise i think this is all
#7923
fastest Losi in region 12 on the rug....
front
56 piston
60 wt oil
blue spring
#1 on shock tower
#3 camber link
4degree caster
losi low roll center
2f pivot block
oneway
standard pulley
3mm droop
5mm ride height
sorex 28 with hpi red inserts
0 toe
1.5 camber
arms forward
2nd thickest sway bar
Rear
56 piston
50wt oil
silver spring
#2 on shock tower
#1 camber link
B hole on outer hub
0 degree hubs (2 degree toe in)
2R rear block
standard pulley
4mm droop (going to try 5mm on friday)
5mm ride height
sorex 24 with hpi red inserts
1.5 camber
arms middle
batteries forward
protoform alfa 2.0
2nd thinnest sway bar
This set up is working killer for me and I hope to end my Losi career next weekend with it. I hope it works for you.
front
56 piston
60 wt oil
blue spring
#1 on shock tower
#3 camber link
4degree caster
2f pivot block
oneway
standard pulley
3mm droop
5mm ride height
0 toe
1.5 camber
arms forward
Rear
56 piston
50wt oil
silver spring
#2 on shock tower
#1 camber link
B hole on outer hub
2R rear block
standard pulley
5mm ride height
1.5 camber
arms middle
batteries forward
protoform alfa 2.0
#7927
Please help a Losi rookie: If I was given a Losi xxx-s touring edition, what would it take to get the car competitive? Besides electronics, motors, batteries, and tires-all of which i already have. Thanks!
#7928
Originally posted by STLNLST
After next weekend I'm running for Schumacher.
#7929
The car should be pretty competitive as is, depending on what level you're racing at. The first thing I'd get though are some threaded shock bodies and get a full set of springs, pistons and oils. Maybe pick up some different rear hub carriers in different angles and different castor blocks. All for tuning options. Ti turnbuckles and hingepins are a good idea as well.
#7930
sundog1,
get a oneway
get a oneway
#7931
oneway is a big yes, as long as you know how to drive one. I've been "teaching" myself to drive one for a couple of months. I'm begining to get faster than I was before the oneway. But at first, it slowed me down quite a bit. I was more of a drive into the corner, brake, turn, and gas it kind of driver. I've had to learn a lot more finess.
#7933
Originally posted by James Nguyen
Just when you get out I pick one up to run in 19t at regionals.
jkerr0043- I hope to have the new car no later than the first week of Jan. It works out great for me since I was planning on taking a small break after the regionals anyway.
