Losi XXX-S
#7936
Originally posted by STLNLST
fastest Losi in region 12 on the rug....
front
56 piston
60 wt oil
blue spring
#1 on shock tower
#3 camber link
4degree caster
losi low roll center
2f pivot block
oneway
standard pulley
3mm droop
5mm ride height
sorex 28 with hpi red inserts
0 toe
1.5 camber
arms forward
2nd thickest sway bar
Rear
56 piston
50wt oil
silver spring
#2 on shock tower
#1 camber link
B hole on outer hub
0 degree hubs (2 degree toe in)
2R rear block
standard pulley
4mm droop (going to try 5mm on friday)
5mm ride height
sorex 24 with hpi red inserts
1.5 camber
arms middle
batteries forward
protoform alfa 2.0
2nd thinnest sway bar
This set up is working killer for me and I hope to end my Losi career next weekend with it. I hope it works for you.
front
56 piston
60 wt oil
blue spring
#1 on shock tower
#3 camber link
4degree caster
2f pivot block
oneway
standard pulley
3mm droop
5mm ride height
0 toe
1.5 camber
arms forward
Rear
56 piston
50wt oil
silver spring
#2 on shock tower
#1 camber link
B hole on outer hub
2R rear block
standard pulley
5mm ride height
1.5 camber
arms middle
batteries forward
protoform alfa 2.0
#7938
will the set up you gave me work with out the oneway, in place with an ordinary diff???
#7941
I ran a diff at Trackside last year for a few nights and didn't like it. The car didn't flow as well, it didn't carry as much corner speed as when I put the one-way in. If you plan on racing at Trackside on a regular basis, I'd say spend the money and pick up the one-way
#7942
Anyone have a good setup sheet of the XXXS for racing on asphalt outdoors on a large track?
Thanks a lot!
Thanks a lot!
#7943
try the LOSI site... or browse through this thread, some guys have posted good set-ups for all kinds to track.
#7944
http://www.losiboard.com/
Go there and look for setups on the Tamiya track from the Reedy race. I think there's a lot of them.
#7945
#7946
then ill have pick one up since im there every week, thnks for all the help
#7947
whats the difference between a locked spool, and a oneway, and would spool be good at Road Rage, kinda the same as trackside.
also, with that new hpi body, is that really that new, or are the proline ones the same?? Scrad- check your pm...
#7949
Where can I find the LOSI BOARD please? Is this not it?
#7950
