Like Tree2Likes
Losi XXX-S
Old 10-16-2003, 07:16 PM
  #7396
Default Re: trinity motor heatsink
Originally posted by eklips
Looking for trinity part number for a motor mount heat sink that was used for the street weapon. This is the one that has a huge blue heat sink attached to the motor mount and can be used w/ the xxxs. Been looking for this mount and cant find the part number.
thanks in advance
do you mean this??...it's not blue but red..haven't seen one with blue color...here's the link..i dunno if thats the one ur looking for
http://dynamiterc.com/Products/Detai...ductID=DYN6820
Los1Fan is offline
Old 10-16-2003, 07:35 PM
  #7397
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
akrcracer: It will move the motor out a little..
I have a one of them from my xx4, let me see how much it moves it...
TRITK3028 XX-4 WEAPON MONSTER MOTOR HEATSINK
Tres is offline
Old 10-16-2003, 07:53 PM
  #7398
Anyone having a harder time setting there losi up on the asphault than lets say a x-ray guy or yokomo guy, seems I have to work alot harder on the asphault than those fella racer, most of the guys here run the x-ray's or tc3's. Just wondering if it true nature is the carpet and to stick to carpet.
Kash is offline
Old 10-16-2003, 07:58 PM
  #7399
are you using a one-way? that really seemed to keep the speed up in the corner. the setup i used and worked excellent for me was the Greg Hodapp asphalt nats setup on the losi website. that should get you started.
lukewilson is offline
Old 10-16-2003, 08:02 PM
  #7400
highwayman's Avatar
nope. i run exclusively on asphalt now, and can definitely say, my xxxs handles great.
i run todd hodge's socal set-up with a few variations, like the rear spring. try it out.
highwayman is offline
Old 10-16-2003, 08:03 PM
  #7401
pro3racer's Avatar
luke, u usin the hodge setup this winter?
pro3racer is offline
Old 10-16-2003, 08:31 PM
  #7402
i use the hodge setup for rubber carpet but now i run foamies so im trying out a custom that im told works well.
Old 10-16-2003, 08:42 PM
  #7403
thank you all, I will check that out.
Kash is offline
Old 10-17-2003, 04:29 AM
  #7404
highwayman's Avatar
Has anybody tried the rear steel out drives ? any improvement?
Old 10-17-2003, 07:33 AM
  #7405
mcsquish's Avatar
thanks in advance
I think the part number is "TK3068", I found it on the Trinity page. I have one, it is very cool. I did though cut on it a bit so the holes in the side of the can are not covered so the air flow is not changed.
mcsquish is offline
Old 10-18-2003, 12:03 AM
  #7406
rcdougie's Avatar
Anyone have a problem with the Losi one-way bearings? I have a brand new one way and when I installed it the right one doesnt spin freely as well as the left one. Any ideas? Thanks!
rcdougie is offline
Old 10-18-2003, 03:54 AM
  #7407
I would think that right side don`t sits right. Cheack the screws again and thighten them carefully
sturla is offline
Old 10-18-2003, 04:36 AM
  #7408
highwayman's Avatar
just a suggestion, check if you have tightened to halves correctly... i made this mistake and it caused a bind.
if all else fails, maybe you just need to re-lube the one-way bearing, after a while it'll free up.
Old 10-18-2003, 05:41 AM
  #7409
could anyone tell me whats the diffrents between piston 56, 60,57 and so on?
sturla is offline
Old 10-18-2003, 06:42 AM
  #7410
highwayman's Avatar
the smaller the number the bigger the hole.
... also the number denotes the drill bit that corresponds to the bore diameter.
