Like Tree2Likes
Losi XXX-S
Old 10-14-2003, 10:41 PM
  #7381
RCTech Member #2
TSR6's Avatar
Originally posted by Kevin K
Troy....yeah you can use them or use the BRP locking nylon wheel nuts they never fall off. Or if you have some spare change get TC3 stub axles they have like one more thread on them so the nuts stay on better. The TC3 stub axels are like 8 bucks each but you wont have to worry too much about a wheel falling off. Or you can go ghetto and flip the wheel nuts over and put them on backwards...
I may just pull the axle's off my original x-s, which aparently are a mm or two longer than my GP+'s. I replaced one with a spare from my original, and it's the only axle that I the AE hexes fit with Losi locknuts.
TSR6 is offline
Old 10-15-2003, 06:56 AM
  #7382
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally posted by Los1Fan
with the steel outdrives..won't that be heavier so if heavier..the more the rotating mass and the slower the car will accel??
It will also help carry a bit more corner speed. You may lose a little grunt off of the line but I don't think that it would be that noticable.
STLNLST is offline
Old 10-15-2003, 07:17 PM
  #7383
pro3racer's Avatar
i'm looking at my belt right now, i when i turn the wheels forward, the whole belt shifts to the right, and when i go backwards, it shifts to the right. It slowly does this, on the tensioner, pulley, everywhere, is this supposed to happen,
pro3racer is offline
Old 10-15-2003, 07:53 PM
  #7384
Trader Rating: 27 (100%+)
It will help increase traction on that end of the car.
MDawson is offline
Old 10-15-2003, 08:03 PM
  #7385
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Ok ...here 's adeal I need a killer set up for carpet race with rubber tires I perfer foam but ,this big coming race ,they use rubber for 19Turn class that's suck
So anyone got the rubber carpet setup for xxx-s gp
OVA is offline
Old 10-15-2003, 08:35 PM
  #7386
dpaton's Avatar
There are a couple on the Losi web site. Check them out, they're both good starting points for setups.
-dave
dpaton is offline
Old 10-15-2003, 09:23 PM
  #7387
OVA
OVA's Avatar
Yes I know about them,but they're for mod motor set up
I need set up for 19T motor
OVA is offline
Old 10-15-2003, 10:48 PM
  #7388
losi jon's Avatar
i am pretty sure those will get you in the ballpark.
losi jon is offline
Old 10-16-2003, 09:41 AM
  #7389
Default trinity motor heatsink
Looking for trinity part number for a motor mount heat sink that was used for the street weapon. This is the one that has a huge blue heat sink attached to the motor mount and can be used w/ the xxxs. Been looking for this mount and cant find the part number.
thanks in advance
eklips is offline
Old 10-16-2003, 03:23 PM
  #7390
pro3racer's Avatar
can anybody answer my question from above, it's kinda important, hehe.
thanx
Old 10-16-2003, 03:31 PM
  #7391
akrcracer's Avatar
Trinity heat sink #??? Some motors run better if you don't cover vent holes on can. Actually if you cover vent holes on can, motor will run hotter.
akrcracer is offline
Old 10-16-2003, 03:39 PM
  #7392
Kevin K's Avatar
Pro3.....your probably seeing the diff move left to right causing the belt to move with it. The diffs are sometimes not tight left to right in the chassis. Losi does sell a shim kit with big shims to take that side to side play out but that side to side play its not going to effect anything...unless its really major slop.
Kevin K is offline
Old 10-16-2003, 05:50 PM
  #7393
pro3racer's Avatar
how do you adjust ride height, my front is way to high(again), and it doesn't say in the manual.
Old 10-16-2003, 05:56 PM
  #7394
unscrew the screws that hold the springs down. you should have any preload in your springs.
lukewilson is offline
Old 10-16-2003, 06:14 PM
  #7395
pro3racer's Avatar
thanx
