Losi XXX-S
#7351
Originally posted by mainracer
I would like to know if it is better to keep the suspension table whitout any loose tight but to keep it freee or should we put a little loose ?
#7353
hey guys,
on the belt tensioner, when the belt goes around the white "ring", does it again come in contact with the pulley on the spur. I wondering if something is binding, because i just broke a belt, and it feels tight, or is it just that my motor is good, and it's a new belt.
#7354
unbolt your motor and see if it spins well.
#7355
Trader Rating: 32 (100%+)
Re: steel outdrives
Originally posted by eklips
what is the part number for the steel outdrives for the xxxs?
thanks in advance
thanks in advance
#7356
it does, the motor is like new, the magnets are very strong too. I woner if it is just sopposed to be like that, i can't remember what it was like before, hehe.
#7357
no, not the motor, i meant see if the car'a drive train spins well.
#7358
Steel out drives
A-3072 Differential Tube (all except LRM & XXX-NT) $2.25
A-3073 Outdrive Cup (Steel) (all except LRM & XXX-NT) $7.00
These are the two parts that you need.... I believe that you need to order two of the out drive cups as there is only one a package.
#7359
R/C Tech Elite Member
Re: Steel out drives
#7363
I mean arms sorry
#7365
Tech racing 1-way
I think with that 1-way you need to use TC3 CVD's bones as well. Im not 100% sure but I think thats the case.
