Losi XXX-S
#5896
yeah i have low roll centers and all that other stuff set up. its just im going to be using a oneway for the first time. Thanks so much for the help! im going to need it i have a state champs point race comming up
#5897
I ran the spool in my car for about a month in stock foam. It was pretty good... very, very good acceleration (better than a one way IMO, spool is lighter...) really pulled the car hard off the corner. The downside though, is you can pretty much forget any mid corner speed... you have good corner entrance speed, because you drive it in so deep, then kinda "snap" off the throttle, almost pitch it through the apex, then hard on the gas on exit. Where with a oneway or diff, the fastest way through the turn, is to flow through very smoothly... kinda blend all the actions together.
As for bearings, Trinity sells a ceramic bearing set for the XXXS. I'm not positive, but I have a feeling they're just repackaged Bocas... They're teflon sealed, very smooth and free especially under load (entering a corner for example). I'm using these in my car, I run them with no lube, and the seals off. They've lasted me a few months now with no problems. I did have one outer race split on a rear hub bearing at the ROAR Carpet Nats during practice... Really not too surprised though, that was a tough layout and I stuffed it pretty hard while learning the track and finding a setup a few times.
Also, the Acer ceramic bearings are awesome, and they do sell a XXXS set.
-Jeff Choban
-Jeff Choban
#5898
The Evicerator
Spools
I still hate the idea of making your car suck to have a "more fair" race... go figure
#5899
Boca Bearings also have an " Ultra Seal Bearing." Double sealed teflon with lube inside of it. What do guys think about that bearing compared to the ceramic? Should I go with boca for my XXX-S or Acer? Thanks for your replies.
#5900
Re: Spools
#5901
Re: Re: Spools
Originally posted by fhubbard
I don't think the idea of using a spool/locked diff or regular diff was conceived to make racing fair, but more so to control the "I'm using a one-way so if I plow through you don't blame me cause I don't know when nor how to brake using it" attitude. Be nice Weissdawg
As fas as a diff goes....the racing wasn't any cleaner last year. It just made for great passes at the end of the straight. Racers were still getting hit from behind.
#5902
O yeah, one of Inglewood's finest Grew up on 64th street and la brea(not far from west blvd and slauson). I now live about 2 to 3 blocks from the forumn (just north of arbor vitae, south of manchester, west of praire, east of la brea). I actually went to Hype Park Elementary until 5th grade, then finished out at Centinela Elem. once we moved to Inglewood. I think the only thing that will REALLY help to keep the racing clean is if drivers were to take some sort of "R/C Drivers ED."
#5903
Re: Almost lost and confused
Originally posted by Team R
Hello all-
IAlso, has anybody tried using the Monster Diff Adjustment Screw Set (part #A-2910) in their diff.? How dose the spring work instead of the washers for the adjustment on the diff?
Hello all-
#5905
Originally posted by xxxkat
Hey Fred what's up(pitted next to you at the state race).STLNLST I hate to say..you were right,Went a lap faster today than I had with any of my other cars(even won)Man a whole lap..go figure..LOL
hey mike...how you been pal. still using our secret weapon with great success. i haven't made the time to actually dyno test it, but i love the results from the track.
#5906
Hey is it true that this is a MOD car, not really a stock racing car?
Also another question, how does this car preform out of box at socal?
thnx
thnx
#5908
associated racer- It all depends on the driver, set up, and equipment. I have beaten my share of TC3's as well as beaten by them.
#5909
#5910
Originally posted by STLNLST
I went to crozier jr high. My aunt lived right across the street from Centinela park. Driver's ed wouldn't help some of the driver's
