Like Tree2Likes
Losi XXX-S
Old 10-22-2003, 07:21 AM
  #7426
See
Trader Rating: 53 (100%+)
Originally posted by highwayman
the oil that came with the kit is too light for an indoor tight carpet track.
needs sway bars also.
This is STLNLST- I think that the kit oil is 40wt and that's what I running on carpet right now with rubber tire's with a 19 turn. I do have a front sway bar installed but I'm also soft with the springs as well. I have blue in the front and pink in the rear. The car is planted. I won 19 turn last week the first time out with this new set up.
See is offline
Old 10-22-2003, 09:17 AM
  #7427
dpaton's Avatar
The stock oil in my G+ was 30wt. I moved to 50, changed the springs, anda few other suspension tweaks (roll center, camber link placement) and I like it a lot more now. I'll be experimenting with sway bars a bit later this week. I run silver fronts and pink rears with CS-22s. I'm thinking 0.050 on the back wouldn't be too bad...
-dave
dpaton is offline
Old 10-22-2003, 01:32 PM
  #7428
dpaton's Avatar
Default non-offset carriers with black ball studs?
I wanted to try the black ball carriers on the rear of my G+, which I'm currently running with the G+ arms and the old style (non-offset) rear hub carriers.
Unfortunately, with the stud in the B position of the carrier the ball cups drag on the inside of the rear rims. Not a good thing in my book. I've shaved as much as I dare off of the cups, but they still contact the inside of my Yokomo dish rims. I hope this is merely a case of me putting something in backwards or equally dumb behavior.
Help?
-dave
dpaton is offline
Old 10-22-2003, 01:37 PM
  #7429
Regional Moderator
Originally posted by JitsuGuy
Where'd you get those white ball cups?
J
sorry for not getting back to you i got them from a local racer and hope to be getting some more .
Ko Racer is offline
Old 10-22-2003, 01:41 PM
  #7430
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Took my Losi out last night and raced again, finally getting the car to work for me. I had more cornerspeed than I've ever had in the past, it was very nice
Randy Caster is offline
Old 10-22-2003, 01:43 PM
  #7431
Regional Moderator
you should have some white goodies real soon i hope!
Ko Racer is offline
Old 10-22-2003, 01:47 PM
  #7432
I cant wait for em Joseph
Got my IS300 body back yesterday, so I'm set for the Lexus race this weekend, gonna be fun!
Old 10-22-2003, 01:49 PM
  #7433
BTW, I've never played with ackerman before, what effect will it have on the handling if I go from the rear position to the front?
Old 10-22-2003, 02:39 PM
  #7434
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
If I'm not mistaken, it'll give you more turn in. Correct me if I'm worng guys. I have yet to play with it too. I know it will increase your ackerman.
Jon Kerr is offline
Old 10-22-2003, 02:47 PM
  #7435
Turn in = good with me I'll have to play around with it...
Old 10-22-2003, 03:06 PM
  #7436
Jon Kerr's Avatar
I just started running a 1-way. I can't belive the cornerspeed. I just need to get used to not having brakes. I keep over shooting corners that I normally wouldn't. And the transitioning back and forth takes a little getting used to but I like it. Now I know what I was missing.
Jon Kerr is offline
Old 10-22-2003, 03:17 PM
  #7437
rtypec's Avatar
When I was not at my pit area, Randman snuck over and stole my cornerspeed. What's up with that?
rtypec is offline
Old 10-22-2003, 03:22 PM
  #7438
Rob Mincey's Avatar
Randman - I recently switched to the front ackerman (in addition to flipping the bellcranks, and moving the draglink ball stud from the laft side of the draglink to the center, and moving the front arms forward using three .060 spacers and the rear arms back using 1 .060 spacer.) After this mod, the car was less twitchy... had less aggression early and mid-corner, but more onpower steering.
Unfortunately, it's hard to isolate WHICH combination of the above mentioned mods made the changes in the feel of the car, but I thought I'd mention my results to you anyway.
Rob
Rob Mincey is offline
Old 10-22-2003, 03:32 PM
  #7439
Jon Kerr's Avatar
Switch to a Losi and you may get it back
Jon Kerr is offline
Old 10-22-2003, 03:33 PM
  #7440
I told you to put a lid on that stuff or I'd be after it... you have nobody to blame but yourself
