Like Tree2Likes
Losi XXX-S
Old 10-22-2003, 03:35 PM
  #7441
Kevin K's Avatar
Trader Rating: 32 (100%+)
Default DPaton.....Ball Cups
Dave....you can grind a fair amount off of the top of the ball cup with out fear...some have even ground so much off that you see the ball stud. From the pic all looks well so just try taking some more off the top of the cup or go to a silver ball stud.
Kevin K is offline
Old 10-22-2003, 04:54 PM
  #7442
tony montana's Avatar
Trader Rating: 76 (100%+)
I know this has probaly been posted a few times but I DONT FEEL LIKE LOOKING THREW 250 pages, I need a good carpet setup for a tight indoor carpet track with foams. I dont have a graphite plus but ever part on the car is graphite. I prefer not to use a oneway because everytime I do the rear end always spins out even when Im not braking in a turn. Thanks!!!!!
tony montana is offline
Old 10-22-2003, 06:56 PM
  #7443
sharkman's Avatar
Trader Rating: 18 (100%+)
check out Mike Dumas set-up on rcmadness madtalk. I just used it this past weekend at madness and it was absolutely dialed.
sharkman is offline
Old 10-22-2003, 08:15 PM
  #7444
Exclamation have a Question
I'm running a Chameleon pro 2 19t what spur and pin should be used ,, i have a habit of burning motors LOL ..
RPM [email protected]
power [email protected]
eff 73.9@ 15.7k
torque 124.0 Nmm
need advice .. thanks inadvance..
mb racer is offline
Old 10-22-2003, 08:25 PM
  #7445
Rob Mincey's Avatar
Well, people here are gearing them in the mid 6's final drive ratio. We've only been running the 19T class a few weeks here, so I can't really speak for the "longevity" factor.
Rob
Rob Mincey is offline
Old 10-22-2003, 08:32 PM
  #7446
Default ROB !!
Rob
thanks ive been running 19 class but seem to get slow 3/4 throu the race .. maybe im geared wrong .. still need more input..the track is 110 by 6o..
mb racer is offline
Old 10-22-2003, 08:38 PM
  #7447
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Mark, YGPM. What brush are you running?
Jon Kerr is offline
Old 10-22-2003, 09:37 PM
  #7448
4070's or 767's and red/green springs, think i should use some thing else?
mb racer is offline
Old 10-22-2003, 09:44 PM
  #7449
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I know that 4499's have a lot of power, and dont seem to kill any of my comms. You might want to make sure the bushings are broken in and oiled as well, those will cause a lot of heat, and start to hurt your power towards the end of the run...
Randy Caster is offline
Old 10-22-2003, 09:45 PM
  #7450
Jon Kerr's Avatar
I've been running 767's. Springs I've been running the Pink ones that Fantom put on it. I'm not sure what they are equivalant to in Trinity but they seem pretty stiff. More of a torque setup. I like a torquey motor. (Torquey, is that a word? )
Jon Kerr is offline
Old 10-22-2003, 09:46 PM
  #7451
Jon Kerr's Avatar
19 turns run bearings dude.
Jon Kerr is offline
Old 10-22-2003, 09:48 PM
  #7452
Post TORQUEY ???
ITS A WORD NOW
4499 BRUSHES RUN BETTER IN STOCK MONSTER MOTORS DONT THEY..
mb racer is offline
Old 10-22-2003, 09:50 PM
  #7453
That must be a sign of how long it's been since I've run 19. I thought they ran bushings... o well.
In that case, gear down a tooth.
Old 10-22-2003, 09:53 PM
  #7454
Jon Kerr's Avatar
Why don't you run 19 on Sunday? That's what I'll be running. I think it's going to be a tough class. I'm just hoping for an A main showing.
Jon Kerr is offline
Old 10-22-2003, 09:54 PM
  #7455
YEA THE EARLY 19'S HAD BUSHINGS BUT I THINK IS THE NORM FOR 19T TO HAVE BEARINGS.. HEY RAD I LIKE THE PAINT ON YOUR LEX,,
mb racer is offline
