Losi XXX-S
#2986
Originally posted by Cain
Also, when you start to setup droop, is a zero droop level the point where the chassis is even with the zero degree mark on the droop gauge? I am alittle confused by all this droop stuff.
#2988
Tech Legend
thanks for all the advice on droop. I finally set my droop according to the settings listed in the manual and wow was I off! (I was running around 8 mm of droop in the rear!) Hopefully this will help me clear up some issues with the traction rolling I was having.
As for the CVDs, how many times have you guys taken them somewhat apart to relube them? I noticed that one of my CVDs was causing the wheel to flop around ever so slightly and I took it apart, relubed it and it is working fine now. Anyone else have this issue and if so how often should I tear down the CVD to relube it? Is anyone running CVD boots? I am thinking of getting these.
Well, better get to sleep, gonna go up to the shop for 9am to get some more practice time in before the race which begins at 12.
Oh, one more thing, I noticed my foam tires had some slight tears in them probably from catching a board or hitting someone else. Do you guys do anything to patch up the tear , I don't mean a complete chunk is missing but a tear has formed sort of like peeling a banana.
thanks!
thanks!
#2989
Tech Legend
one more thing, how much better are titanium screws than the stock ones? my main issue is I want them to be less prone to stripping (i haven't had a problem with that recently since I now use ball drivers, but you never know). Also, does the titanium screws include the droop screws? How much weight will I save?
#2990
is weight really an issue? i know guys that run stainless steel screws and can still get their cars under weight, and that would be a stronger car. but i would guess you could save .5 - 1oz.
#2991
Locknut problems
Has anyone managed to find low profile aluminium 8-32 locknuts to stop them catching on the boards??
I couldn't find any at tower or horizon hobby.
#2992
Re: Locknut problems
#2993
Alu caster blocks
Are there any aluminium caster blocks other than 0 degree?
#2994
are the dynamite aluminum kunckels worth the $27.50 ??? are they durable. they look cool and if they are stronger i might try them, any feed back?
#2995
100 pages, suck it TC3 thread
#2996
shrekair
Dynamite = GPM which is not widely known as one of the higher quality alum parts makers. Many people complain about parts not having holes in the right places, tolerances being different between two, supposedly, identical parts, etc. I haven't had any negative experinces with the personally, but I have run into many who have.
#2997
anybody got xxx-s they would like to trade for a yok.I know this is not the right fourm but I thought I would take it right to sourse of xxx-s's
Thanks,
Drew
Thanks,
Drew
#2999
what kinda of yok, details and extras, pics?
#3000
how come?
i just got mine and i think it's not bad
