Losi XXX-S
#1936
Ill Factor and all other xxx-s drivers. I highly recommend getting some 3/32 e-clips and putting them on both sides of all the hinge pins. The hinge pins are even recessed just for this purpose. The set screw for the pins may be enough, but if you have the e-clips on there, you have nothing to worry about as far as the hinge pin coming out.
Hope this helps,
Jits
Hope this helps,
Jits
#1937
Thnx Blazn420 & all other for the help. I will try the car without a drag brake profile. WOW the car gets faster than it already is. NICE
#1938
One ways...
With all the talk of the One ways, has anyone tried playing with the 41T Pulley in the rear with a one way up front?...
I have been meaning to try this, but on race day I have to set up my girl friends TC3 and my car. Needless to say, time tends to be short, if the set up is gawd awful I would not have the time to change it back.
#1939
Mad Cats from what I have read if you run the 41 tooth pulley in back and the One way up front you basically get 4WD again, so to me it doesnt make sense to do it.
#1940
Ill Factor
Okay, I do admit my lodgic is a bit in left field here, but...
Off trottle, your car is 2wd, as the One way only drives the front tires on power. Giving the car off power streering
The 41T would spin the rear tires faster then the front at full trottle. Furthermore the 41T in the Rear is said to give more on power steering.
Basicly my lodgic falls out like this, At full traction to the rear wheels the car would have less drive train drag (basicly 2wd under full traction), with lost traction in the rear, the Front would drive the car and under cornering, the rear wheel would roll slightly better with the 1.78 drive train ratio.
With this fuzzy lodgic, I have not tried this.. but was woundering if someone else has...
#1941
Cats
Cats your onto it in theory. The ratio would change but the car would react as if 4WD
#1942
Does anyone know if the Red ball links that come with the Matt Francis edition Losi truck will fit on the xxx-s? I think they'd look cool.
Thanks,
Jits
Thanks,
Jits
#1943
I have the red ball cups on my xxx-s. I just measured the length of the stock ones, marked the red ones and cut them to the required length. They do look cool. Kinda adds a personal touch!
#1945
Doug, how did you cut them? Ginsu?
Jits
Jits
#1946
Originally posted by kansasracer
Trips:
I run my XXX-S with blues Losi springs up front and the purples springs in the rear. It doesn't make sense, but it works.
I am running the standard roll blocks and Sorex tires with yok firm inserts. (on carpet of course)
People look at my car and can't believe it works that way. Now let's see if the setup works after I put that one way in....
Trips:
#1947
1. What are the advantages and disadvintages of running a one -way on a carpet track?
2. What is the advantages of getting the shortened front shock bodies? Do you need get the shortened shock bodies for the rear of the car?
#1949
Thanks for the tips guys. I am putting together a pit box from scratch since I have been out of cars for years. It is costly, tough but fun to do. From bashing the boards, what is the most common parts to break on the XXX-S? Our LHS is short on XXX-S parts so I will have to look elsewhere. Are any of the XXX buggy parts used on the S? The LHS has a full compliment of those.
#1950
whats a good place to mount the capacitor from a TC2 esc??Pics would be great.
