Originally Posted by Randy Caster
Cool stuff, thanks for the help.
Do you guys break many servo savers? -James |
Originally Posted by exint2
apologies in advance but I've just purchased an L4 as my first (for 19 years) 12th car.
I'm looking for a basic set up guide that explains how the various adjustments (spring, damper, grease, tension etc) to the rear pod effect the handling balance of the car. I'm sure that there is a link in one of the 13800 posts on this board but it could take a bit of time to find it ;) http://home.sc.rr.com/mlufaso/rc/12l4/index.html Have fun with it! Nick |
Originally Posted by blue hornet.
hey all...was wondering if anyone here could give a clue on this....
i have a RC12LS graphite, first with quick change front suspension, or so the box says. it has all the kit parts and spares and is in pretty good nic. just wondering what it would be worth????? any ideas? thanks. |
servo saver saver
Isn't the point of a servo saver to give or break first before you do damage to your servo? Wouldn't making the servo saver stronger break your servo?
-James |
anyone....
Its not a current car so i'd guess you would get $50-70 but you never know on eBay. If someone really wants one anything can happen. |
cheers
Originally Posted by JamesArluck
The way a servo saver works is that it is a two piece system. One piece rigidly connects to the servo output, the other to the ballstuds that the tie rods mount on. There is a spring between the two pieces. The idea is that under hard impacts the spring will compress and allow the pieces to rotate against each other, lessening the shock transferred back to the servo. Making the ballstud area stronger has no effect on the servo saver's ability to perform this function.
-James Oh ok. Now it makes sense. Thanks for the explanation. |
Anyone know if there are better .020" front springs than the ones AE makes? One hit and the spring on that corner is toast.
What do you guys recommend for a battery discharger? I need it to be able to do 4 cells as well as 6 cells.
I've been using the same 0.020 spring for at least 30 runs (and countless crashes!!) but it still look okie to me when i last check it? how to tell when i need to replace it? |
is300zx,
Novak smart tray does 1-6 cells and has adjustable cutoff from .1 to .9 also has dead short mode. |
Wolf use to make some just for the 12 scale, i know they still make some for 10th but there a bigger id.
Originally Posted by yellow15
just a silly question, how do you know when the spring is toasted?
I've been using the same 0.020 spring for at least 30 runs (and countless crashes!!) but it still look okie to me when i last check it? how to tell when i need to replace it? As Kevin said when they are blown out they get shorter and you can see it pretty clearly. |
| All times are GMT -7. It is currently 03:37 AM. |
