-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
RPM #6 09-27-2005 08:58 PM
I's the 3.1 for 75$ a good deal or not?
odpurple 09-27-2005 09:01 PM
Originally Posted by 1armed1
Any help guys?
Should I change tires or setup?
Dayton
Usually with purples the front tires are the ones that get sticky, giving more steering later in the run. Post the rest of your set up and maybe someone will have an idea. Front springs (.020?) Camber, Caster, ride height, etc.
odpurple 09-27-2005 09:04 PM
Originally Posted by rcshark
hay i have the ahara special 1/12 and would like to know if i should convert it back to the tpate car or not i will run on aspalt. i know nothing about this car other then its in good shape and i have parts! lol
I have run the Hara car on asphalt (that's what it's for) and thought it was pretty good. A t-plate car may be easier to drive if it's the right one. I found that my Yokomo was faster than the Hara because it was easier for me to drive. If I had the talent, I would run the H12.
CarlosG. 09-27-2005 09:05 PM
Any help guys?
Dayton
Try going to softer springs up front, like .024. The.050 sound way to stiff. Also try a the silver spring on the rear shock.
1armed1 09-27-2005 09:08 PM
odpurple,
Front springs are .020, .5 camber, 10 caster, battery cups turned to move the batterys forward.
3.5mm front ride hieght and 4mm rear.
Dayton
jrrc 09-27-2005 09:08 PM
1armed1........need more info. track surface/tire traction compound/ride height/tire size/etc
1armed1 09-27-2005 09:09 PM
Carlos, I have the silver spring on the shock, the .050 is the spring steel t-bar. Front springs are stock, .020 I believe.
RPM #6 09-27-2005 09:09 PM
I'm having a prob with the car lifting up when I corner.
Still Bill 09-27-2005 09:13 PM
1armed1,
Now you have the attention of two of the Three Wise Men...When Crashby chimes in, you will get some great input....And I'm listening!
1armed1 09-27-2005 09:13 PM
jrrc,
Fairly new ozite, paragon oderless,3.5mm front hieght 4mm rear.
Tires are
Front purple at 1.785"
Rears are pink at 1.935
All tires were freshlt trued before the race.
odpurple 09-27-2005 09:22 PM
Originally Posted by RPM #6
This is how knew I am, what the H is the Swedish Meatball
Inside joke! :lol:
OK, here's my new car, Team Laje SpeedEvil...way cool.
oh, yeah, it's from Sweden.
odpurple 09-27-2005 09:31 PM
odpurple,
Dayton
This set up should give tons of steering, hmmm. Ideas, anyone?
theisgroup 09-27-2005 09:36 PM
i think you wait for the traction to come up. you will be chasing setup until then. i also think that purple is too stiff, you should go to a double pink or 2 stage purple. not sure how the ss tbar work, but i would go with a .078 fiberglass tbar or maybe even an .080.
camber should be set for tire wear and should not be used as a tuning aid. but .5 seam a little low. are you getting coning? if so you sould increase the camber.
Still Bill 09-27-2005 09:42 PM
Originally Posted by odpurple
Inside joke! :lol:
Is this a mod car?
What is that t-bar made of?
Don't quite understand the front tie rod attachment points and that piece with the semi-circle cut in it???
Please bring this Saturday.
jrrc 09-27-2005 09:44 PM
The problem is after a couple laps the tires "tack" up real good, it pushes worst than a 2whl buggy with a 9 turn.
Is it good for a couple of laps, then starts to push or is it bad from the start? A car can push if you get off line (in the marbles) and my take a lap to get the tires clean. A body or chassis rubbing can cause a lack of traction at one end of the car.
I think the best thing to do is ask someone at the track. Your problem is kind of hard to troubleshoot on the net.
