Originally Posted by JayBee
Where's the defense buddy ;) ... I'm guessing mincemeat is on the menu when the racing starts :sneaky: :lol: Is this what you call 'pot-stirrin'? -JB
Oops! I'm in the lead. Always racin' |
I just built a new L4, there is no toe in/out on the set-up sheet so I assumed there is zero toe in/out. Am I correct?
odpurple-
I need some advice on setting the gear mesh on this T-Fource. It seems like the bottom of the rear pod is restricting me from moving the motor further to the front of the car. Do I need to shave some already spare material from it? :( -JB |
odpurple-
I need some advice on setting the gear mesh on this T-Fource. It seems like the bottom of the rear pod is restricting me from moving the motor further to the front of the car. Do I need to shave some already spare material from it? :( -JB You have to remove material from the T bar or change to a smaller spur to get the desired gear ratio. |
Toe in or toe out is only a tuning aid. Use it accordingly. |
Originally Posted by Crashby
OD is on his way to my house. We are racing tonight in Ripon at the annual Revo race.
Originally Posted by RobS
Those are the Jaco 2 stage tires, they've been out for a little while now. I have a set but have not tried them yet. :nod: :nod:
can't find any place listing them and none of the sister companies using the same foam (CRC, Parma, etc) have anything listed either? |
Originally Posted by EricF
Fast-
Haven't heard from Max lately, I'll email later toaday. I've been thinking about getting the CRC t-bar chassis (I can't recall the name) or I might buy a Assoc L4 and get the DP conversion OR I might get a 2nd jrXs for the rug. I can't deceide. E still tossing and undecided about whether to cross to a T-bar. if you still have your red ed. CK. you don't need a 12l4 to get a Q12 set-up and going. just get a t-bar, t-bar pivot parts, t-bar spacers (3 in bag)......you have all the rest. the Q12 uses the CRC adjustable servo mounts, dampner tubes, etc. other than that if you just want a new car, i would get the T-Fource anyway didn't see you today? Cory had his CK dialed today i only had 8 feet on him at the end of 8 min. i ran my Q-12 tape edition (CRC parted) tape ed. Shawn ran a silver Q12 (Yok parted). 2 others there today had 12ths.........didn't run :weird: |
Originally Posted by Matt Howard
does anyone have any experience with the CEFX car? I was thinking of trying one out but I haven't heard of anyone's experience with the car and that funky front end :p
i have a c-12, it is a greatcar, very simple to work on...the only part i broke(twice) last winter was the front bumper...both were my fault....other than that i love the car.... i got mine from www.kthobbies.com, however, josh is a bit behind, so they dont have any....but if you give kraig a call, he will know more.... matt |
Originally Posted by fast-ho-cars
CRC T-Fource or DP Q12
still tossing and undecided about whether to cross to a T-bar. if you still have your red ed. CK. you don't need a 12l4 to get a Q12 set-up and going. just get a t-bar, t-bar pivot parts, t-bar spacers (3 in bag)......you have all the rest. the Q12 uses the CRC adjustable servo mounts, dampner tubes, etc. other than that if you just want a new car, i would get the T-Fource anyway didn't see you today? Cory had his CK dialed today i only had 8 feet on him at the end of 8 min. i ran my Q-12 tape edition (CRC parted) tape ed. Shawn ran a silver Q12 (Yok parted). 2 others there today had 12ths.........didn't run :weird: I think that I'll get the T-force. Is this car a traditional t-bar car or is the t-bar only used to connect the rear pod to the chassis? I think its the latter as the t-bar is graphite not fiberglass. Anyone have any opinions on the T-force? JayBee have you run yours yet? E |
Nope had to work, I'm also at work now (sunday), but I did go by there today to take a look. Also, nope I don't have my red CK. So I need a car period.
Rear Ride Height Adjusters and Rear Bulkheads
Hi all
I am having a lot of trouble getting the ride height adjusters to sit cleanly in the bulkheads causing some binding in the bearings/axle. I ordered up a set of IRS adjusters but was wondering what everyone else has done to fix this besides sanding off the edges. Thanks |
rinkrat99, filing those to fit is the only good way.
Deep breaths Jaybee and repeat after me....
"IN WITH THE GOOD (breathe in) OUT WITH THE BAD (breath out)" Do this for 2 minutes then have a bottle of beer. Repeat this whole thing 12 times and you will be fine. Chris |
Jaybee,
Spektrum glitched? I thought that shouldn't happen? |
| All times are GMT -7. It is currently 03:53 AM. |
