-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
dakrat 03-20-2005 10:05 AM
where did u add shims on urs? what do u recommend?
crimson eagle 03-20-2005 10:10 AM
I put mine above the a-arm but I do trim the plastic part which captures the ball so it can sit right down onto the steering block. If you look closely, it is possible for it to rub on the inside.
Chris.
dakrat 03-20-2005 10:12 AM
why not put shims under the balls? that will give clearance between the steering block and the arms. i also noticed on my l3 that the instruction says add one shim under the upper ball
crimson eagle 03-20-2005 10:15 AM
Dakrat,
yes that would solve the problem too but it would mean that you would get more camber going around the corners and your castor would be slightly different. now if you ask me if I could tell the difference I'd say probably not.
Chris.
JLMG1971 03-20-2005 12:11 PM
Hi all
I was cleanning the 12L4, and doing a major overhaul and discovered a crack on the bottom layer of the chassis, right where the aft left side of the T-plate is.
I know I can still race the car for maybe a couple a races since is only one layer of the carbon fiber, but I think is better to change the chassis. What do you guys recommend, to buy a normal 12L4 or to upgrad to a different chassis, if so which one?
Jorge
dakrat 03-20-2005 12:14 PM
thanks crimson.
jl, check out the bmi converstion for l4. looks really neat and it performs.
Thraex 03-20-2005 12:19 PM
Or the slapmaster conversion!:sneaky:
dakrat 03-20-2005 12:23 PM
is the associated front end the same as the crc front ends? i mean really idetical? also, who makes a battery case for 4-cell saddle packs?
chris_morrison_ 03-20-2005 01:08 PM
yes they the same
JLMG1971 03-20-2005 01:49 PM
Where can I see the BMI chassis for the 12L4, I looked for it in the BMI website but there's nothing there for the L4
JL
odpurple 03-20-2005 02:05 PM
JL
There's a thread on the Electric On Road forum where you can find some pictures of the BMI car.
Take a look at the PRC Quad 12 at www.powellracingcomponents.com
It's a great car!
whynot 03-20-2005 03:42 PM
what do you guys think of the old school front end compared to the new one.
mike
sg1 03-20-2005 04:29 PM
BMI 1/12 CONVERSION
JLMG1971...
The BMI conversion is not on the BMI website as you found out. You can call BMI directly and ask about the availability. There are some pics on the BMI 1/12 conversion thread if you want to see them.
Wayne
protc3 03-20-2005 05:43 PM
i apologize for the website.i have to update it with all of my new releases.if you have any questions please feel free to call the shop or shoot me an email.
the conversion will be available thoughout the next 2-3 weeks.i will be starting another run of them this week.currently we are sold out but will be filling old and new orders as they are finished.
thanks,
Jason
dakrat 03-20-2005 06:25 PM
i just got done building the t fource and this car looks sexy! i cant believe how free the bearings are! they will spin forever which concerns me, does it come pre-lubed from factory? what the recommended maintenance on these bearings?
