Originally posted by crimson eagle Crashby, OD, JRRC, I do have a question for you guys now...... are you now all my b!tches? :lol: :lol: :lol: Chris. Hey OD & JRRC. We have lulled the unsuspecting Brit into a false since of superiority. Now when we knock him off the top, he will fall much harder!! Oh, and by the way, Mr. Crimson Eagle, we are not going to share anymore of our speed secrets with you. The deal was that you where not supposed to beat us with our own tricks!! It's too bad you are not coming up to the Ground Pounders next weekend. It's a two day race. Three qualifiers on Saturday, two on Sunday and the mains. You could come up on Sunday only and just use the two to out qualify us and take the win. You’re flying pretty high right now. Sunday was one of the best days of 1/12th racing I have had in a long, long time. There was less than 3 hundredths difference between first qualifier and third. I can't wait for next month. |
Originally posted by Boomer So, I'm running an L4 with dampner tubes to the sides (IRS with white springs). I'm still using the tweak screws in the T-Bar. Ppl fronts, green rears. I don't have the sizes, but they're cut down just a bit from brand new. CEFX body. Rake is flat, RH is about 4-4.5 (we have a transition from banked oval to flat so I have to run just a bit high so as not to ground out on the transitions. . .) Car is pretty much hooked up, a bit neutral under mid and high-speed cornering but very controllable. However, at the lowest speed portion of a turn, the car wants to pivot hard. It's like once it gets to a certain low speed, it catches and hooks hard. That's about my only problem not driver-related! :D Any thing to look for? Is the car diving in under deceleration and hooking? Or is it hooking when you apply the throttle coming out of slow corners? If it's the latter, try a little more caster or the next stiffer front spring. Or soften up the rear a little more. |
it's just prior to hitting the throttle.
the car turns in wonderful. It's great mid-corner. It's just past mid-corner when I'm about to roll back on throttle. . .that's when it hooks. |
Hi Crashby,
yes that was a whole lot of fun and easily the best asphalt race day I had by many times. If you think I'm not going to do a little gloating after the grief you guy gave me on the driviers stand before the final you are sadly mistaken. The way you were driving it will be your turn soon, you were scary fast man. We will see you guys next time around, I can't race twice in a weekend, that really isn't going to happen. My problem is, if you guys don't show at Ripon, there may not be any 12th scale there this week so I'm not sure what I'll be racing. take care guys, I'll see you in a couple and we'll do it all again. Chris. |
I'm coming to Ripon with my JRX-S and 1/12th scale.
Originally posted by Boomer it's just prior to hitting the throttle. the car turns in wonderful. It's great mid-corner. It's just past mid-corner when I'm about to roll back on throttle. . .that's when it hooks. I would first: Increase the front caster Then stiffen the front springs Then soften the rear |
Originally posted by crimson eagle Hi Crashby, yes that was a whole lot of fun and easily the best asphalt race day I had by many times. If you think I'm not going to do a little gloating after the grief you guy gave me on the driviers stand before the final you are sadly mistaken. The way you were driving it will be your turn soon, you were scary fast man. We will see you guys next time around, I can't race twice in a weekend, that really isn't going to happen. My problem is, if you guys don't show at Ripon, there may not be any 12th scale there this week so I'm not sure what I'll be racing. take care guys, I'll see you in a couple and we'll do it all again. Chris. Hey JRX-S Bill? Where the heck were you?!? You missed out on some big fun! |
Crashby,
I understand your reasoning there and yes Ruben and Charlie are more than capable taking the honors. It was a shame though that more of the carpet Rookie guys did not show up. The guy in the green car, can't remember his name, we need to give him as much encouragement as we can tou show the others that it isn't such a daunting thing. Maybe OD can have a sale of a couple of the 40 or cars he isn't going to use :D. I certainly felt that racing Stock wasn't that slow even though it is a big open track. Then again i had a great day so I'm not the best person to ask. I wonder if Ruben has the results up yet, I want to check my laps :D I didn't think I could have as much fun on Asphalt as I have been on carpet, but as usual, I was wrong again. I'm a little concerned about Ripon this week as you guys are going to groundpounders. Hopefully we can get a heat running. Chris Chris. |
We may use our company airplane this weekend. Race at GroundPounders Saturday afternoon jet to Rippon and be back for GPs on Sunday. Nascar drivers do it all the time.
Chris......one more win and you have to run a transmitter with a steering wheel. Results are up, but I get an error when I use the link. |
Hey, Crimson Eagle!
We did not get to talk much after the race and I wanted to ask you how you liked that Niftech traction compound? Did you put any on the front tires for the main? Obviously it worked for you! |
Props to Chris. It should be fun having a good 12 scale field this summer. Chris i found my speed issue, it was not the motor. I was only was getting 4.0 volts to the motor. Oops.... You would think i would learn to check this in the few weeks i have been racing lol.
KC RACING MOTORS & BATTERIES STOCKTON R/C RACEWAY CHARLIE |
Jim,
I have been trying the wheel radio a little ..... But no. It isn't going to happen, I can't coordinate throttle and steering with that thing. Crashby, Yes I liked it, and no didn't put any on the front for the final. It seemed like very consistant throughout the whole run. I'm interested to see how it performs in the heat. Charlie, Yes that would definitely cause a problem. Didn't this happen to you not so long ago? Or was it Ruben? I wanted to ask all of you what your tire wear was like? Mine was pretty ferocious, I was running pinks and purples. Chris. |
Originally posted by crimson eagle Jim, I have been trying the wheel radio a little ..... But no. It isn't going to happen, I can't coordinate throttle and steering with that thing. Crashby, Yes I liked it, and no didn't put any on the front for the final. It seemed like very consistant throughout the whole run. I'm interested to see how it performs in the heat. Charlie, Yes that would definitely cause a problem. Didn't this happen to you not so long ago? Or was it Ruben? I wanted to ask all of you what your tire wear was like? Mine was pretty ferocious, I was running pinks and purples. Chris. |
27/88 with fairly smal tires about 1.78". I tried taller gearing but it was just flat in the infield.
Chris. |
| All times are GMT -7. It is currently 07:19 AM. |
