Originally posted by dakrat john, so only jaco tires are direct fit? I like having a flanged bearings also. Sometimes I use it on the inside of Jaco wheels instead of a washer. |
someone point me out to figure out the ratio. It's been a long time I know u have to measure your tires maybe and do something. also point me out to about what to start out w/.
new to the pancars. |
Fried...
Man.. I seen a number of racers searching for CRC bearings because they are so smooth and build the perfect diff. They are really affordable and after trying others, the CRC bearings are all I use now. Just my 2 cents... |
Originally posted by insideline Fried... Man.. I seen a number of racers searching for CRC bearings because they are so smooth and build the perfect diff. They are really affordable and after trying others, the CRC bearings are all I use now. Just my 2 cents... |
7.2v Servo?
Anyone know what servo's on Josh's car? Counting the batteries, looks like he's using a 7.2v servo. Looking for a mini servo with high torque since it provides great holding power at the turns.
http://www.cefx.net/images/car_cefx12_2.jpg |
Originally posted by tc3Guru someone point me out to figure out the ratio. It's been a long time I know u have to measure your tires maybe and do something. also point me out to about what to start out w/. new to the pancars. |
10L4 diff = 12L4 diff?
:confused: can i use 10L4 diff ring on L4??i found that they dun fit completely |
Re: 7.2v Servo?
Originally posted by revzalot Anyone know what servo's on Josh's car? Counting the batteries, looks like he's using a 7.2v servo. Looking for a mini servo with high torque since it provides great holding power at the turns. http://www.cefx.net/images/car_cefx12_2.jpg |
1/12 asphalt
could someone post baseline setups for 1/12 outdoor asphalt,would like tire selection,and chassis difference from carpet. just getting a jump on springtime. thanks in advance
1/12
Anyone here build/design there own car [from scratch that is]...pics..thanks
Re: Re: 7.2v Servo?
Originally posted by Tim Stamper ko 949 the 949 in Cyrul's car is a six volt servo. Somewhere in the forums on the CEFX website Josh says he uses six cells to get faster speed from the servo, but the factory (KO) doesn't recommend it as that is not the voltage it's designed for. Kind of a disclaimer if anyone happens to fry thier sevo from over-voltage. I've been using KO 947/949 servos for some time and they are plenty fast on 5 cells, but then I'm no Josh Cyrul either :lol: |
I know this has probably been asked 9004567832 times but, what servo for 12l4?
Has anyone got any pics of the new rear end on Josh's CEFX from Cleveland?. Rick
servo
Originally posted by nmt6789 I know this has probably been asked 9004567832 times but, what servo for 12l4? |
dampner disks
whats the proper way to set this up ? do you still use teflon tape on the plate ? this for a 12L4 thanks for the help...
| All times are GMT -7. It is currently 04:45 AM. |
