-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
Crashby 08-10-2004 10:02 AM
Re: C12
Originally posted by rice98w
anyone know of a place that stocks the C12 cefx and sells them reletively cheap?
any links would be great
thanks
Try K T Hobbies. Kraig probably will have the best prices on all of your 1/12th scale needs.
http://www.kthobbies.com/store/car_kits.htm
Crashby 08-10-2004 10:08 AM
Re: IRS Castor Blocks
Originally posted by lem2
What are the advantages of using the Aluminum Castor Blocks and the Upper arms in my 12L3? What differences will it make from the stock?
A bunch of us will be running 12scales on asphalt, could not wait to run them!!!!
Thanks!
Lem
They will provide you with options of reducing the rate of camber gain during suspension travel and the option of changing the roll center in the front of the car. Additionally, with a slight modification to the Associated lower control arm, you can change between 5 degrees and 10 degrees of reactive castor.
mo 08-10-2004 10:17 AM
Originally posted by AdrianM
Yup, Schumacher hasn't made a 1/12th in over 20 years.
Our Factory drivers run whatever they want in 1/12. Paul Wynn runs a RC12L3 due to his long history with AE and Reedy. Only Masami has been sponsored by Reedy longer than PW! Andrew Cartwright and myself run Hyperdrive Pro 12's . Mike McMahon is a long time CRC driver and runs a T-Fource 12.
I didn't even know Hyperdrive was still around. LOL I still have an old Hyperdrive LX 1/10th pan car in my closet somewhere. Do you have any pictures of the car?
AdrianM 08-10-2004 11:19 AM
They still make tons of oval cars. I'll take a pic this week and put it up here. It is basically a RC12L3 with a 1/8" shorter wheelbase (like a Switchblade) and CRC damper tubes instead of plates. The chassis is .090" so it works on Asphalt and Carpet. All you need to change is t-bars.
Taz_S 08-10-2004 12:34 PM
http://www.hyperdriveracing.com/12scale/hk1000.cfm
here you go Mo
AdrianM 08-10-2004 12:51 PM
The current cars have CRC alloy damper tubes and the new IRS Graphite Big D ring diff. The also have alloy IRS rear pod plates. Like I said...its all tricked out.
Chris08527 08-10-2004 02:18 PM
anyone out there have some pics of a CRC bloody six pack
i would like to see how people set up the electronics and battery packs
thanks,
Chris08527
rdub202 08-10-2004 02:18 PM
how do you guys hold on ur electronics just normal servo tape- like the double sided foam tape stuff? and batteries-just normal black electrical tape? cuz i just bought some 3300s and now my L3 finally has all the parts to b run i think lol
AdrianM 08-10-2004 02:26 PM
The best servo tape in earth is 3M interior/exterior mounting tape. It is a dense gray form. It sticks like crazy yet releases when you want it to. It also comes off in one piece.
To hold your cells in you need a fiber reinforced strapping tape. You can get 3M 3/4" at the grocery store but that is kinda overkill. Hobby shops sell a 3/8" wide version in black or clear that is better suited for the job.
jas1 08-10-2004 02:33 PM
you need fibreglass reinforced tape to hold your batteries in the car.
RICE98W
i live in the uk, and i bought my car through kraig at KT hobbies, the guy was great, very helpfull, cant recommend him enough. does a good price on jaco's too.
rdub202 08-10-2004 02:34 PM
thanks jas and adrian
what about servos do u use micro sized or full size or does it not matter cuz i have heard both?
jas1 08-10-2004 02:52 PM
suppose you could use a full size servo if you had too, space may be a little tight though.
1/12 servos all so have alot less torque, i picked a futaba 9650 up for $69 then there is also the ko servo i've seen for $82
rdub202 08-10-2004 03:00 PM
okay cuz i talked to someone and he said that he has seen a lot of the smaller servos burnin up and has never had a problem with his
AdrianM 08-10-2004 03:05 PM
I use an Airtonics 94141. Its a mini servo..they last forever.
Crashby 08-10-2004 03:34 PM
Use MIP double sided tape. It is white in color and it is the best servo tape ever made. It holds like glue and comes off real easy.
To tape your batteries in your car use either nylon strapping tape, the tape with the most strands is the strongest or you can use battery strapping tape made from a thin mylar plastic material. Speed Merchant sells the Mylar tape.
