-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
fast-ho-cars 10-20-2003 10:57 AM
Originally posted by stormperson
fast- I find it extremely hard to believe that those pods (espically the left side) are perfectly true and completely perpendicular to the chassis. epsically if you have gone through those many other parts, lol. Also are your tubes still perfectly smooth without any fluid in them (ie no binding or anything?) If so you are one lucky guy! lol;)
change the fluid in the aluminum tubes after every 3 heats (1 days worth of racing) ....no binding when dry or lubed. i must be soooo lucky to have the ONLY other perfect set ever made.
since i started racing asphalt 12th two weeks ago, that chassis is on the verge of getting changed (front end damage). clipped a dot and flew 15 feet. just used a machinists ruler to visually check them out, didn't notice anything bent, etc. i will check the plates again on another flat surface when off the car.
CypressMidWest 10-20-2003 11:25 AM
Originally posted by IMPACTPLAYR
Make that 13 mine and my buddies where all smooth from the get go.... that's 3 sets from me!!!LOL Cypress just likes to dis all of the stuff I own!!!LOL :lol: :lol:
It's not you impact, just personal experience, I never had an aluminum set that didn't require quite a bit of "re-finishing" in order to work smoothly. I actually went to plastic tubes on my CRC car before I switched over to the Rev. 3. The plastic tubes have always been more consistent for me. My best friend is a CRC sponsored driver and he says they're alot better than the used to be, but I'm still sold on the plastic tubes.
speedxl 10-20-2003 01:20 PM
i run for doug and i actually use the ones for a corrally . i would use the ones for irs because of the spring option.
but i got freebies from my buddies at corrally usa so i run those. they all work.
stumper1 10-20-2003 02:42 PM
IRS Axle
Thanks for all the replies!!
Can anyone tell me the size of the bearing in the spur gear?
DPowell 10-20-2003 02:46 PM
The bearing in the spur gear is 1/4 x 3/8 unflanged.
D.P.
stumper1 10-20-2003 02:55 PM
D.P.
Thanks!! Now if the parts I ordered from Speedmerchant will ever show up my Quad12 will be up and running!!!
EricF 10-21-2003 04:28 PM
Hey Mr. Powell,
Any time or progress on making a battery retention system for the CRC car similar to the one you designed for you car.
Eric from Tucson
I've seen one of you chassis' a guy that I race with at Competition Hobbies bought one, looks very impressive. I've been trying to find a used 12L3 for cheep so that I can try your chassis, but no luck yet.
RC Paperboy 10-21-2003 05:12 PM
Hey guys,
On carpet, what would be the effect of going from a grey to a pink rear? Im loking for a little more forward bite and better wear, I know the pinks will wear better, but any comments on the bite?
fast-ho-cars 10-21-2003 05:40 PM
saw this on the TRINITY talk site
http://www.rcracechat.com/forum/attachments/JG_3.JPG
someone was asking who makes this 12th
ERIC
DP also makes his chassis in a tape version. in MOD some like to run the rec-pk on the t-bar. he also sells chassis parts separate so those who chose to can stick with their disk dampner system
PINK tires on the rear. i tried it to get more grip but it was too much forward bite at times and they caused the car to be twitchy in the turns. when the rear end traction breaks it is more violent, made the car hard for me to drive. i went to WHITES although softer than PINKS they were better on our carpet when it was new and once the black groove set in they were almost like the PINKS. if you want more traction than GREYS try the TRC GRANITE Compound: half BLACK outside / half WHITE inside.
DPowell 10-21-2003 05:55 PM
Originally posted by Fike
Hey Mr. Powell,
Eric from Tucson
Eric,
You are not the only one to ask that. I will borrow a CK from one of my local customers and get some dimensions off of the chassis. He doesn't need it anymore, he stepped up to a Quad12.
Shouldn't be a problem, the posts should be the same as I use on the Q12 plus or minus a little in height and the carbon fiber battery hold down would also be a shorter version of the one on the Q12.
Also, rather than buying a used 12L3 and tossing most of it. Pick up a front end(old school or dynamic, your choice), Micro shock, IRS pod plates and 12 ball diff and you're mostly there.
I've got the carbon fiber parts covered and I make T-bars also.
D.P.
2Tenths 10-21-2003 06:11 PM
Fast - That looks like a P.T.I. Virus. I think its a Japanese company. They also make a sedan with rocker style suspension (2 rear shocks and 1 front).
fast-ho-cars 10-21-2003 07:22 PM
if it is a PTI? it is heavily changed from the last one i saw pictured which had no floating pod or t-bar...it relied on the flex of a narrow cut section.
xxxgrumpxxx 10-21-2003 07:57 PM
Just getting into 12th scale!!!
I am just entering th 12th scale scene and pretty much decided on CRC Carpet Knife, GM SX9 speed control, and a P2k2 stock motor.
Now could anyone give me suggestions on servos?
Thanks, grump
DPowell 10-21-2003 08:07 PM
Looks like a home built to me. The chassis looks like it was cut from some cheap carbon fiber that showed up on Ebay a while back. Too thin and way to much flex for a racing chassis.
D.P.
stormperson 10-21-2003 08:14 PM
grump- I would highly suggest reconsidering and looking at the Speemerchant Rev. 3, it is very similar to the CRC knife, however there are a few distinct features that make it a much better car.
-Adjustable battery position (huge in 12th scale)
-Adjustable and smooth side links
-stiff chassis (the crc flexes alot in the rear)
-low roll centers (the crc ones are sky high and to make the car handle considerably better you have to install speedmerchant side links, which have adjustable roll centers)
-Old style front end, its much simplier and its still the hookup for stock, espically for people just getting into 12th scale. the dyanmic strut from end is very poorly molded and requires alot of handfitting to work properly.
Also I would suggest a Monster stock motor, they are the best for any track hands down.
I have not had any expeariances with GM speedo's so I cannot comment, however I will say I have yet to be dispointed with an LRP quantom comp
As far as servo's each company basically makes a servo for 12th scale. All of them are pretty good, I personally run airtonics, however I have seen some bad batches of them from time to time, however I still go back to em, lol. Futaba and KO Propo are the other choices that I have heard good things about (the KO servo is wicked fast though, and I have heard its to the point where its detrimental, even for certain not to be named A main mod 12th scale drivers, lol)
if you have any questions please feel free to ask!:)
