-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
XRaycer 10-08-2003 07:15 PM
speedxl- I'll take your advice, it'll probably do well. you actually run a 19t 12th scale class at your track? sounds like fun:nod:
XRaycer 10-08-2003 07:20 PM
Tire choice
I like the TRC tires aside from the cool color they seem durable for the weight. I use other tires but when the racin is intense I'll have the TRCs on:sneaky:
kiyano 10-09-2003 12:20 AM
Trinity Reflex12 was exhibited by RC Show in Tokyo. This is one of the picture:)
http://www.kimihiko-yano.net/Image2/PA090001.jpg
Visit my page for more pictures.
RC Paperboy 10-09-2003 03:59 AM
The only thing more hideous than that graphite is the purple graphite on my switchblade.
Dont mean to offend anyone if thats not their thing, but I really dont like that colour.
sands 10-09-2003 06:46 AM
You've got some good stuff on your page on building techniques. Although I can't read Japanese, the pictures are more than enough to get the ideas across.
thanks.
Big KAT 10-09-2003 03:45 PM
I use a durometer on all of my tires when they break out of the package. I never just purchase one set of tires, I usualy purchase in bulk quantities, enough to last me the racing season. This way I can match the tires better for a more consistent feel.
SpeedyTC3 . . . Where do you buy tires in bulk? Your method sounds like good advice.:)
jcrouse 10-09-2003 06:48 PM
T-bar Shimming
I'm new to all this RC stuff, especially 1/12th scale. I have the above mentioned car. Periodocally I see someone mention shimming the T-bar, usually the front. It's even listed on the setup sheets on Associated's web site. Could some explain this phenomon to me. What is does and what to sue for shims.
Bobby Z 10-09-2003 07:44 PM
Novak GT7 Power Module
Can anyone running a Novak GT7 in their 12th scale car give me some feedback on the new Power Module wire harness that is available for older GT7's and now shipping with the latest batches of that ESC.
Novak claims cooler operating temps, higher RPM so I picked one up and wonder if anyone has any info or feedback on its performance.
Lastly, if anyone has any pics on how they installed this wire harness in their car that would be awesome. The board that the diode sits on is a little big and I am trying to find a way to get it in the car without hitting the body.
Bob Zahn
ultra_low_life 10-10-2003 01:18 AM
Tire diameter
I have read so many ariticle about rollout, but they all talks about the same thing, selecting gear ratio, tire diameter changes, ...
But what I would like to know are:
- How to select a starting tire diameter?
- Is the lower profile tire going to give more active and aggresive feeling when cornering, since it is so close to the wheel. Higher profile will give the car more rolling?
David Root 10-10-2003 02:54 AM
ULL,
Tires with more foam on them give more traction. The closer to the wheel, the less foam and flex for bite. You will find a sweet spot where they wear slower and perform best. I don't true my tires (GASP!) I just run them from new till they are worn out, I'm kind of cheap and sponsor my son's racing too. Most people true them to a starting size because they are more consistant which counts a lot.
David root
stormperson 10-10-2003 03:47 AM
bobbyz- Its really there so the ESC doesnt blow up, which GT7's have a tendacy to do, ALOT. The best way i have seen it mounted so for was by taking off the shrink wrapping and ziptieing it to the case through where you would normally zip tie the capacitor. (although this might void your warrenty, i dunno, i saw it on a factoy novak driver's car, so to him it really didnt matter, lol).
Brolzy 10-10-2003 07:35 AM
Re: ULL,
I've always done the same thing...you're not alone. :)
Casey 10-10-2003 08:33 AM
Any pics of this Novak thing ?
Bobby Z 10-10-2003 10:27 AM
Check out the Novak Website. Go to their products section and then to the Accessories link.
Here is the link:
http://www.teamnovak.com/Buy/ind_buypgs/5638.html
RC Paperboy 10-11-2003 09:52 AM
Whats teh difference between the rev2 and rev3? Is it just the old front end and new front end?
