Cool...I also heard you can get the unobtanium rear foam tires the Yokomo drivers had on these.
Originally Posted by InspGadgt
(Post 11571389)
http://www.rctech.net/forum/members/...ultiwheels.jpg |
Originally Posted by RedBullFiXX
(Post 11571412)
Originally Posted by LonnyJ1950
(Post 11571865)
Ok so how does Y rubber fit in there? :weird:
At the rate we use up tires I would rather save 3-5 bucks a pair and stick with Jacos or CRCs.
Originally Posted by AdrianM
(Post 11572596)
Originally Posted by hanulec
(Post 11572708)
Or BSR :)
You can buy the Ulti tires in 3-packs which makes the fronts $12/pair and rears $13/pair. Pricing is different for some of the foam compounds, but that pricing isn't too far off of CRC, Jaco, or Parma. (Parma Black/Orange from AMain, the only place that I can find them in stock right now, is even more expensive). All depends on what you are willing to pay, though.
Hey Dave,
I have the same results I really like these tires got to run them a few weeks Back.Rob at KO was very helpful with the tire info. There very consistent and the offset are close to the jaco's
(Post 11570252)
Been testing a bit with the Ulti product
The wheels are awesome, and have a decent amount of off-set to fit the R5 at under 172mm I have found these foams to be very consistent, much more so than CRC or Jaco And far better quality wheels 13.5 SS IIC X-MF; 1/3 sauce X-MR: full TQRC X-HF 7/8 JTG 20m X-SR Full 20m For a bit more front bite J-HF 7/8 JTG 20m X-SR Full 20m Adjusting for a green track, only 1/4 inside front, for 5m http://www.rctech.net/forum/members/...e7031-ulti.jpg |
I've been running he Enetti wheels/tires lately to save a bit on costs...at under $8 a pair it saves quite a bit. On our asphalt track running 2 sets of tires in 4 rounds of running per race day...I go through both sets in 3 to 4 race days. So I am spending about $40 every 2 months for Jaco tires or $31 every 2 months for Enetti tires. Granted it isn't much when I look at it like this...but it sure feels like I'm going through tires fast.
(Post 11573310)
I really like the Enetti rims, super light and they are just flexible enough not to shatter like fine china like I've found the CRCs to do if you have a strong hit to the front and the wheel contacts the steering arm.
I've found the foam to be OK in the firmer ranges, but their softer Pink/Magenta compounds leave a bit to be desired on our carpet at least. I've also found their wheels to be inconsistent when it comes to quality of the glue job, roundness of the rim, and overall foam placement. The enetti foam in the natural rubber range seems to be 2 shore softer than the CRC/Jaco ranges. |
Originally Posted by mike ivy
(Post 11573274)
Hey Dave,
I have the same results I really like these tires got to run them a few weeks Back.Rob at KO was very helpful with the tire info. There very consistent and the offset are close to the jaco's Good stuff Very happy Rob agreed to import these |
hey guys i just got my son a gen xi. when i tried to install one of my nano-tech 1 cell it wouldnt fit. the battery was to wide, battery measures 93.7mm and where the battery goes is the car measures 93mm, would it be ok to file the left and right plates so the battery will fit, thanks guys
Getting ready to update my CRC GenXL for outdoor asphalt. What would be the best version? I was thinking the Altered Ego?
| All times are GMT -7. It is currently 08:09 PM. |
