-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
JeffC 01-11-2018 08:15 PM
Originally Posted by danthrc (Post 15127539)
Jeff, do you have any pictures of that mounted body? Im about to mount up an RC8 and wanted to see what your description looks like in photo.
I'll post pics tomorrow. Anything specific you're curious about?
Josh-n-ya 01-11-2018 09:06 PM
Originally Posted by DesertRat (Post 15127099)
A bit pricy, but I still ordered some. At least the dollar is a little stronger compared to yen these days.
I ordered as well. I hope that two rears and two fronts come in the sets. If I ordered only one of each I'm gonna be bummed because I have to order again.
PROMODVETTE 01-11-2018 09:49 PM
The aluminum setup wheels are in stock stateside here too. Im not sure what shipping is from japan to compare the pricing.
http://www.srossimotorsports.com/shop/index.php?route=product/product&path=62&product_id=68
Pinkz 01-11-2018 10:45 PM
added to wiki, CRC Carpet Knife 25 Japan spec link. appears it has features that would it welcome at lower traction non black carpet tracks and for those who still run asphalt
JeffC 01-12-2018 07:32 AM
Photos: https://imgur.com/a/1pxAL
I hope this shows whatever you're looking for. Honestly, to me it just looks like another 1/12 car! I guess I don't pay much attention to how others mount their bodies. I'm still pretty new to this 1/12 game, but I'm an open book and will gladly share what I have learned-- good or bad.
Speedychris22 01-12-2018 07:45 AM
Originally Posted by JeffC (Post 15127631)
Use a tweak station. Borrow one if necessary.
I was using the coin trick until one of our local fast guys (gubbs3 on here), suggested I really should use a tweak station. I'm fortunate that my home track, MMR in Minneapolis MN, has tools such as tweak stations and a tire truer available for racers to use. After learning to use the tweak station properly, my car has been noticeably more consistent. I was just being lazy using the coins.
The coin trick is fine for a super quick check, but if time allows, just get the car on a tweak board.
Question when using the tweak station are u guys unscrewing the pod links?
JeffC 01-12-2018 08:04 AM
Disconnect the damper tubes.
TOADYY 01-12-2018 08:06 AM
Don't worry they come in pairs.
I wish there were set-up wheels for my Pro 10/1:10 pan.
Josh-n-ya 01-12-2018 08:11 AM
1/12 set up wheels
Haha. After I ordered from Japan.
Rugspin 01-12-2018 10:09 AM
1/12 set up wheels
A friend had these and I have hunted for them for years now. Thanks for the Link
JeffC 01-12-2018 10:19 AM
Those setup wheels look awesome. Thanks for sharing the link! If I had an extra $85 I'd order a set.
danthrc 01-12-2018 11:58 AM
Thank you Jeff, that is fine. I was really wanting to see how aggressive the "side height" (profile) of the car looked when cutting it above the normal cut lines making the top of the body closer to the track.
eazy70 01-12-2018 02:18 PM
Originally Posted by Einsman (Post 15127226)
Anyone here running a Tekin RS Gen 2 on their 1/12?
Yes I was for a few years up till 2 weeks ago now running the rs pro black edition 1s. It's a bit heavier but noticeable difference driving on the track. My dyno also shows between 3-4% more power on a 17.5t.
InspGadgt 01-14-2018 10:04 AM
What I do to make this easier is mount the body to the height I want it over the tires. Then take the body off and put the car on a setup board (Bigger works better). Use some of spacers to lift the chassis up until the bottom of the chassis is even with the tip of a sharpie pen laying on the setup board with the cap off. Then you just put the body back on, hold the sharpie pen down on the board as you draw the bottom cut line around the body.
LonnyJ1950 01-14-2018 11:25 AM
Are you all cutting above the trim line? Isn't/was't there a rule that said no cutting above the trim line?
