Originally Posted by DirkW
(Post 15093663)
:confused: My two Xerun XR10 Pro 160A both have an external 2-cap-bank. My XR10 Justock has a single external cap. The 1S apparently has a single external as well - so which one do you have, that has them internal? I only know of XR8 versions with internal caps...
Originally Posted by PROMODVETTE
(Post 15093534)
Whats the consensus on capacitors? My Orca's had the nice 4 bank, but this Hobbywing only has a single. Is there any aftermarket cap setup that will be best for 17.5?
Does someone know what viscosity the blue spooge from Speedmerchant is? 30k?, or maybe stiffer?
Originally Posted by vafactor
(Post 15094984)
R/C Tech Forums - View Single Post - Speedmerchant Roadkill 10 235mm Pro10 Pancar |
Originally Posted by eazy70
(Post 15089857)
Well I have motor dynos, minipro and a turbo dyno 45. I will be running a few tests between 12awg 13awg and 14awg. All from tq. All tests will start with identical temps. I will be able to see if the motors are making more power with a thicker wire.
Sorry for taking so long. Well after hours of testing, mostly repeating the same tests over and over, only cause I was in disbelief. Between the 12awg and 14awg the difference was almost nothing. I didn't even bother with the 13awg wire. Maybe I should try 16 awg next. I just don't have any. |
Test from 16-18 to see if there’s any noticeable drop.
Originally Posted by Antimullet
(Post 15096305)
(Post 15096187)
....Well after hours of testing, mostly repeating the same tests over and over, only cause I was in disbelief. Between the 12awg and 14awg the difference was almost nothing. I didn't even bother with the 13awg wire....
I'm not laughing at you, just the people who keep telling everyone to use ridiculous wire on their (usually blinky) cars as it gives them more power. Will be interesting to see what difference 16awg makes, even then I would only expect it to cause a difference in high power motors. |
I have a turbo30 dyno I've been playing around with, I was using 16ga tq wire at first but after changing motors a few dozen times the solder wicked and I put some 14ga I had laying around on it. I didn't see any actual difference in my results, even re-tested a motor.
Originally Posted by Scirocco
(Post 15097267)
I also have a CE turbo 45, the problem I have with it is even if I max out the tq to 15.9 it doesn't pull the motor below 6000 rpm. The dyno is fine for knowing mid range to top end power. So I bought a minipro where I bought the heaviest flywheel they have, and able to start the pull at any rpm including 0 rpm.I usually start around 2,500 rpm, during a race we rarely go below that. For the wire test I start the test at 1000 rpm and it pulls around 66 amps at the start of the pull. |
Ya, its not the best setup for brushless motors but ive learned more about tuning brushless motors in the last few week than I did in 4 years of racing. I even sorted a few of my "dud" motors out making them useful. I also have a fantom facts machine but not sure if its worth the trouble of getting to work.
vafactor- check out shur lube. I bought all of them from wind tunnel racing 1-6 and diff lube as well. as far as wt goes not sure but I only use their lube so I've never worried about it
took out about Pro One..."no longer selling to the public" on WIKI
fixed broken link for Trinity Motolyser DC 1S Booster Part # TEP20249 and added output info. on the link item description it states: "A must have for 1 cell lipo racing due to ROAR banning receiver battery packs." did ROAR actually ban receiver packs in pan cars? i did some searches only found some controversy on 1/8 cars years back |
Anyone have a great method for lubing the kingpins? I have just been putting a glob of 20k on end of a hex driver and awkwardly lubing above and below the steering block and arms. Any way to do this more effectively without disassembling the kingpin/steering block assembly altogether?
Originally Posted by JeffofSpace
(Post 15098855)
I put a little dab of oil/grease on the pin and kind of roll it between my fingers so that it gets a thin coat. Assemble, wipe any extra oil off the pin and go. |
| All times are GMT -7. It is currently 03:58 AM. |
