Like Tree2991Likes
1/12 forum
Old 02-20-2011 | 02:54 PM
  #35491
Originally Posted by Delawareguy
Thanks. What about the Hitec servos? Half the price of the Futaba so they are kind of hard to ignore especially since I only paid $30 for the car. Are they junk?
JR 3650 is a great 1/12 servo, I also use it in my 1/10 pan car as well. Fast, and reliable. Should be had for around $60-80
I have run the Hitec in my 1/12, and they dont have a good mini servo for racing. I would stay away from them. Their larger servos are very good though. (In my nitro I use the HV 7940TH servo, simply amazing. )
Shawn
Shawn68z is offline
Old 02-20-2011 | 07:35 PM
  #35492
LonnyJ1950's Avatar
I think if you compare the specs, you will see why the Futaba or JR are worth a bit more. Hitec makes some good stuff, but their mini servo is not on a par with the others. A 1/12TH car puts a lot of strain on the servo because of the extreme cornering speeds.
LonnyJ1950 is offline
Old 02-20-2011 | 07:39 PM
  #35493
protc3's Avatar
I would definitely go for a good servo. I like the JR,KO, or the Futaba. Centering has always been a problem with the Hitec servos and it makes for a car that wanders down the straight.
protc3 is offline
Old 02-20-2011 | 07:48 PM
  #35494
What about Savox? Looking at their website they list the SAVSH1350 as being comparable to the Futaba 9650 but $10 cheaper. They also have the SAVSH1357 which appears to be faster but not have as much torque. Both are the same price and I've heard good things about the brand in general.
Delawareguy is offline
Old 02-20-2011 | 09:27 PM
  #35495
Smile Re..servo
PROTC3.....what he said...+1 The HiTec mini doesn't center accurately enough....It will drive you crazy, you will wish you had spent a little more money. You got enough to learn as it is.. The T-Force is good car !!!!
TJ
THEBIGBULL is offline
Old 02-20-2011 | 11:21 PM
  #35496
Pattojnr's Avatar
i think you can add the new sanwa one to the wandering list.
Pattojnr is offline
Old 02-20-2011 | 11:38 PM
  #35497
Chubba's Avatar
Hi there, I am currently using the Futaba 9650 and it is a great servo.
Chubba is offline
Old 02-21-2011 | 01:23 AM
  #35498
JayBee's Avatar
I concur....the Futaba 9650 is a great servo to use.
JayBee is offline
Old 02-21-2011 | 01:33 AM
  #35499
M7H's Avatar
M7H
I run the SH1357, very fast servo 0.07/60, 2.5Kg torque, which is more then enough for 12th scale....
M7H is offline
Old 02-21-2011 | 03:21 AM
  #35500
protc3's Avatar
That is the worst feeling. Its almost like giving your car a lazy eye.
protc3 is offline
Old 02-21-2011 | 07:45 AM
  #35501
I am using Futaba's 9602 and the 9650 both awesome servos
jdeadman is offline
Old 02-21-2011 | 08:23 AM
  #35502
Thanks for all the help. I've decided to not be that cheap so I'm not getting the Hitec but instead I've ordered a Savox. A little cheaper than the Futaba and a free t-shirt!!
Old 02-21-2011 | 08:31 AM
  #35503
theisgroup's Avatar
a wondering steering servo is one of the biggest thing that deter racers from this class. it is soo important that the servo is acurate, that it makes the cars seam tweaked. i have seen many people shy away from the class because their cars just don't work well and it is usually a servo or servo saver.
theisgroup is offline
Old 02-21-2011 | 09:14 AM
  #35504
wingracer's Avatar
You got that right. Years ago I got an airtronics servo on the advice of the hobby shop. The first few races it did just fine but then I started having a centering issue with it. I went through the car and found one ball end that was just a bit tight. The servo had so little torque that that was all it took to screw it up. Replaced that ball end and all was fine for one more race before it completely died. Slapped a 9650 in it and never had another issue. Had I been a noob, I probably would have slapped the whole rig on ebay and given up in frustration.
wingracer is offline
Old 02-21-2011 | 12:04 PM
  #35505
Also this is my 3rd winter on the 9602 not too bad I say
jdeadman is offline
