Like Tree2991Likes
1/12 forum
Old 02-10-2011 | 08:11 AM
  #35431
OVA's Avatar
OVA
What's the best 17.5 motor brands is everyones is running for 12th 1S lipo?
OVA is offline
Old 02-10-2011 | 08:42 AM
  #35432
wingracer's Avatar
no boost, LRP.
boosted, LRP, Tekin, Duos are all good.
wingracer is offline
Old 02-10-2011 | 10:55 AM
  #35433
OVA's Avatar
OVA
Originally Posted by wingracer
no boost, LRP.
sorry No timming
OVA is offline
Old 02-10-2011 | 11:17 AM
  #35434
no boost, LRP.
So that's why the A-Mains of both 17.5 non-boosted and 13.5 boosted at snowbirds were full of Duo 3's??
peter_robinson is offline
Old 02-11-2011 | 02:46 AM
  #35435
M7H's Avatar
M7H
Originally Posted by CFR
XERUN-120A-1S ESC
ran this last night with the following setiings but it has loads of punch for 2 mins then goes soft but still quick
which way to go with the setup please?
Motor = GM10.5 2010 model on 47.3mmpr
Punch level 9
Neutral 6%
Boost 55
Turbo Slope 12
Turbo 5
Start RPM 3000
Turbo Delay 0.2
Timing Acc 150
3.0v cut off
You are using Turbo to gain punch?
I would choose a milder boost setting (45 instead of 55)
Set turbo higher, from 5 to 15 (total timing will be the same)
Maybe even an higher start RPM.
Turbo delay, to 0.3 or even 0.4 seconds.
This will arrange the turbo only kicking in on the back straight.
I think you lose the punch feeling because either, your draining your Lipo to early, or the motor gets to hot, so the rotor looses it's magnetism....
M7H is offline
Old 02-11-2011 | 05:10 AM
  #35436
wingracer's Avatar
Haven't tried a 3 yet. Boosted I love the 1 and 2 but for no boost I get a bit more out of the LRP.
Old 02-15-2011 | 12:05 AM
  #35437
landau's Avatar
On last weekend, it held JMRCA KANTO nationals.
starting order after 4 round qualify as follows,
TQ Yanai (team lije) lije 2011?
2nd haytto (team crc japan) CRC XL
3rd naoto (team yokomo current 1/12th world champion) R12
4th toshiki (team crc japan) CRC XL J-spec
5th daisuke (team kyosyo 2010 JMRCA finalist) CRC XL
6th hideo (team corally, former JMRAC national chapmppion and IFMAR finalist) 12SL with using SP 12M front parts
7th masahiro (team corally former JMRCA national champion) 12SL
8th kousuke (private kid 11 years old) speed merchant rev6
A final round 1 (from high angle)
http://www.youtube.com/watch?v=hN5MOql81rI
A final round 2 (from low angle)
http://www.youtube.com/watch?v=lee6YqG2lug
result
1st yanai (team lije)
2nd hayato (team crc)
3rd toshiki (team crc)
...5th naoto (team yokomo)...
landau is offline
Old 02-15-2011 | 05:57 AM
  #35438
Chubba's Avatar
hi there, I am new to 1:12 and have now been practicing for a month at my local track.
After a full day of practice I was wondering what should I be doing to keep my motor in top condition? ie what to oil etc. motor spray needed? if so what parts etc.
Also the diff what do you use to clean the diff balls. During the day I would normally rebuild and new diff oil around 3 times.
Chubba is offline
Old 02-15-2011 | 05:59 AM
  #35439
20 SMOKE's Avatar
what motor brushed or brushless for the diff balls you can use motor spray or brake clean,clean them and the gear check the rings for grove if all is good use diff grease and rebuild
20 SMOKE is offline
Old 02-15-2011 | 03:18 PM
  #35440
Chubba's Avatar
Thanks. Currently I am using team power and lrp brushless motors.
Chubba is offline
Old 02-15-2011 | 08:00 PM
  #35441
wingracer's Avatar
There isn't much you need to do to the things. A small drop of oil on the bearings every now and then and you're pretty much set. Brush or blow the carpet fuzz out of them every now and then if you want.
Old 02-16-2011 | 06:36 AM
  #35442
Hi!
I have a 1/12 Xray XII, and I put there a GM Genius 120 and I need some help :P.
Yesterday, for the first time, I test the car, and the throttle was a bit strange. Today I install the software, but I like to know if there are some setup, or if someone have a GM Genius 120 setup for 1/12 scale.
I run with 4600 NiMH, on carpet, with GM 6 Delta ( I will test more motors but now is the 6 Delta installed)
Thks !
Young_Z is offline
Old 02-16-2011 | 08:58 AM
  #35443
SNIPR's Avatar
I just recently picked up a CRC Gen XL. I looking to find out what tools I would need with 1/12:
Droop Blocks
Droop Gauge
Ride Height Gauge
Tweak board, etc.
Also we will run 10.5 brushless or 19t brushed at my local track. Is there much difference between motors for this class? I am thinking of going Team Orion 10.5 Vortex (new can) as far as esc I am thinking Tekin RS as I can pick those up cheap used. I just don't have the 2-4 weeks to wait for the Xerun 120a 1s to ship.
Now I do have the receiver pack one dynamite 180mAh 2s 20c 7.4v and Protek RC LiFe 6.6v 200mAh. Do you need special charger to charge LiFe packs?
Thanks in advance for all help!
SNIPR is offline
Old 02-16-2011 | 03:08 PM
  #35444
andrewdoherty's Avatar
Droop Blocks
Droop Gauge
Ride Height Gauge
Tweak board, etc.
A 10.5 with a Tekin and timing etc should be power more than anyone in your position just starting out could ever want. As for tools you will not need droop blocks. The tools I use about any time I work on my GXL goes...
Allens
.050"
1/16"
5/64"
3/32"
Nut Drivers
3/16"
11/32"
Ride height gauge
sliding camber gauge
turn buckle wrench
needle nose pliers
tweezers
calipers
good set of eyeballs
Pane of glass for set up
You can get a tweak board if you want but I wouldn't say its necessary.
I can't help ya with the charge info as I run boosters.
andrewdoherty is offline
Old 02-16-2011 | 06:41 PM
  #35445
Team Speedy's Avatar
You'll need a particular charger that has the capability to charge A123 or LIFE cells. Understand that Lithium-ion Polymer (LIPO) are entirely different compared towards a LIFE pack. For example to name a few different chargers that enable to you to do both LIFE and Lithium-ion Polymer you could look at the following brands: (**Assuming you don't already own a charger capable of charging a LIFE pack)
  • Hyperion
  • LRP
  • Muchmore
  • Checkpoint/Racers Edge
Team Speedy is offline
