-   -   1/12 forum (https://www.rctech.net/forum/electric-road/37-1-12-forum.html)
wingman2 11-22-2009 03:43 PM
Thanks for that mate, so everything is as it should be. Great! Cheers.
Dane 11-22-2009 06:52 PM
What's the best way to hold down wires to the chassis? Has anyone tried hot glue? I want to have a secure placement but also be able to remove the electronics at some point in time and still have the wires in tact.
georgec 11-22-2009 07:23 PM
Hello, Just getting back into 1/12th scale and I was looking for pretrued donuts. Anyone know where to get the best price!
Thanks in advance, georgec
Dane 11-22-2009 07:27 PM
http://www.nexusracing.com/index.php?cPath=144_188_342
:nod:
STRICTLYSERPENT 11-22-2009 09:12 PM
Im sure this question gets asked alot but here we go im new to electric and have a serpent s120 and need a esc and motor whats the best set up?I want to run the expert class.Thanks
InspGadgt 11-22-2009 09:47 PM
Your best bet is mounted and trued tires. Pretrued donuts are no longer true once they get mounted. Stormer as well as other on-line shops carry the full line of Jaco tires as well as Parma and CRC.
corallyman 11-23-2009 01:13 AM
Shoe Goo if you want to do that but it's not needed really. Just bundle it neatly, use shrink tubing or CRC use to sell these clips that were small. They would servo tape down then you inserted the wires into the clip.
Steve
georgec 11-23-2009 03:46 AM
Thanks guys , I'll go the premount route.
Dane 11-23-2009 05:10 AM
Speed controls have really changed the game in the last year with special programming,timing advances, etc. The nicer ESCs can be hooked into your PC for almost infinite adjustment and the advantage is absolutely noticeable on the track. Choices include the KO Propo BMC, Tekin RS & RS Pro, LRP SXX, and the upcoming Novak Kinetic.
With that said, motor choice really isn't a huge deal but the Trinity Duo and Duo 2's are popular. I think if you have a good ESC with those adjustments mentioned, that motor will scream regardless of which sticker is on it :)
avs 11-23-2009 06:18 AM
hey tony,
i presume you are referring to the roadrunners 1/12 expert class. i haven't been there, but their website indicated it is a 4cell 13.5 class but that was a 1 yr old post. so now they could also be running 1cell lipo, still with 13.5 or maybe 10.5. (i have some almost new 4cell packs if you are interested)
these are spec class motors, so there isn't be a huge disparity between brands, but they aren't identical. duo2 are highly sought after but you will see tekin speed passion novak etc all running well
esc choice is where things matter. CRC's advanced electronics unit is the latest hot ticket in the speedo war, but the Tekin RS has upgradeable software and there are pretty regular updates (check out their thread). i also see lrp and KO, but i am not familiar with their models.
one thing i noticed at ocrc this past year,where there was a combined 4cell 17.5 and 1s lip 13.5 class, was everybody went to 1s lipo, (the latest batch of nimh are really good performing but are a pain to deal with compared with 1 lipo cell.
swimbikerun 11-23-2009 07:14 AM
I tried searching this thread and was surprised there wasn't an answer for this. In 17.5/13.5 1s lipo on carpet the front tire to use are Jaco Black/Purple (or equivalents) because they are more 'consistent' throughout a run. Why is that? Why do you lose steering with 2x Pink or softern compounds less than half way through a run? Someone explained it is because there isn't enough heat generated in the tires in the stock classes so the harder compounds change less than the softer ones. Is there another reason?
Dane 11-23-2009 07:35 AM
I would venture to say that the softer compounds would tend to be "stickier" and pick up more carpet fuzz/debris etc. As the tires heat and become sticker, they would tend to pick up this debris and lose traction in the middle of the run. The harder tires would provide enough grip but not be so soft they pick up a lot of the junk on the track.
georgec 11-24-2009 03:39 AM
I just ordered the Novak Havoc 1s esc with the 17.5 motor combo. No need for a booster or receiver pack! It should be in the end of next week. I'll try it and report back:tire:
TrevCoult 11-24-2009 02:00 PM
12th Scale Transmitter Set Up
I've just posted up an article on setting up your transmitter for 12th scale written by Andy Griffiths up on www.carsrcracing.co.uk.
Trev
Lee_123 11-24-2009 02:24 PM
Originally Posted by georgec (Post 6637081)
...ordered the Novak Havoc 1s esc with the 17.5 motor combo. ....
Where did you order it from?
